D16y8 harness plug questions
Old Jun 14, 2007 | 10:07 AM
guedo148's Avatar
Default D16y8 harness plug questions
I have a 98 Civic Ex that originally came with an OBD2A D16y8. I swapped it out for a B16 but am rebuilding that so i bought another OBD2A D16y8 engine and OBD2A D16y8 harness to put in there while i rebuild the B-series.
i bought the harness and engine from different people. i just finished plugging in the wiring harness and i have a few questions because there's some extra plugs that shouldn't be there and i don't know why.
i know the harness is OBD2A because it fits in my OBD2A ECU. I have my original D16y8 harness but some of the plugs are converted to B-series so i didn't use that.
here are pictures of the differences, see if you can help me out:
ORIGINAL D16Y8 HARNESS (notice it has 3 plugs for the ECU- 2 gray and 1 blue:
NEW D16Y8 HARNESS (there is an extra gray plug on the ECU side of the harness):
---DRIVER'S SIDE---
ORIGINAL HARNESS (only has one plug)
NEW HARNESS (has same exact plug as original harness but also has an extra plug and i have nowhere to plug it in)
---IACV----
ORIGINAL HARNESS (there's a 2 pin connector that fits up to the IACV)
NEW HARNESS (i don't know if it goes to the IACV but the only plug i couldn't find a place for is a 3 pin connector that doesn't fit the IACV on the D16y8 i picked up)
There are also a few extra plugs on the tranny side of the engine.
so can i just leave the extra plugs unplugged or what? does anyone know what this harness is from? the guy i bought it from said he just pulled it out of a 96-98 civic ex. there's a lot of wires on that one plug going to the ECU so i'm sure if i left that unconnected, it would cause some kind of problem.
and what about the IACV? how do i rewire the 3 wire plug to fit the 2 wire connector on the intake manifold?
if anyone can help with any of the questions i have or help identify the harness that'd be great, i really want to get this running asap. thanks a lot.
Old Jun 14, 2007 | 10:26 AM
VRD^don's Avatar
Default Re: D16y8 harness plug questions (guedo148)
you picked up a automatic d16y8 harness.. you dont need to use those extra plugs...just plug up the ones that you need and convert it to 2 pin IAVC..
Old Jun 14, 2007 | 10:29 AM
guedo148's Avatar
Default Re: D16y8 harness plug questions (VRD)
oh ok, awesome. so how do i rewire the IACV plug if i'm going from 3 wires to 2? do i just leave one out or what?
EDIT: ok, they both have yellow and blue wires but the A/T harness has an extra orange one, i'm guessing i just leave the orange one out, correct?
Old Jun 14, 2007 | 11:06 AM
VRD^don's Avatar
and you have to depin the ecu side aslo..
Old Jun 14, 2007 | 11:12 AM
HondaPartsHero's Avatar
Technical Hero
HotrodHooptie
Jan 6, 2018 02:59 AM
JDMTiger4
Aug 7, 2011 06:48 AM
lvzero0
Nov 5, 2005 10:12 PM
lvzero0
Nov 5, 2005 09:59 AM
goat442003
Jun 21, 2003 07:16 PM
