whats a best way to store a engine?
i have a complete gsr engine swap sitting in my storage room and i dont plan to do the swap until maybe september because i need some money and time to gather all the minor parts.so it is sitting in a room temperature storage.what is the best way to store the engine?drain the motor oil and tranny oil and refill with the fresh fluid or ?
thanks
thanks
Or you can get a jack stand and place the motor on there if its already seperated. You can also go to Home Depot or Lowes and get some of that neon green 3M tape and cover all the openings so that nothing finds its way in your motor if you have any open ports etc.
Remove all the spark plugs, squirt some oil in the holes, turn over buy hand, re-install plugs. They sell engine bags you can use as well. I'd do that and you should be good to go.
And yes, drain the fluids.
I think just turning it by hand every once in a while is one of the best things you can do for a sitting motor. I have heard good things about marvel mystery oil in the cylinders for a sitting motor also, it will just burn off when you start it next time.
JDMAF
12
Feb 2, 2011 11:02 PM
PowerLeg
Transmission & Drivetrain
11
Jan 11, 2009 10:29 AM
duck22krazy
Dec 8, 2008 02:52 PM
