92 CX With Rear Disc Problem
Old Jun 14, 2007 | 06:35 AM
EGLUVN's Avatar
Default 92 CX With Rear Disc Problem
I got a 92 cx hatch with a gsr rear disc brake conversion. But the brake still feel just as shitty now as they did with my rear drums. Ive heard it might be my porportioning valve. it that right. i have like 90% pad life all around
Old Jun 14, 2007 | 06:40 AM
cxSHOE's Avatar
Default Re: 92 CX With Rear Disc Problem (EGLUVN)
without going bigger in the front this is common. go bigger in the front and you will see the difference. the front brakes is what takes the majority of the pressure of stopping a car>>> hence why front brakes are bigger than the rear in almost every car.
Old Jun 14, 2007 | 07:11 AM
IIXtremeHansen's Avatar
if u have same problem before the swap check your master,booster, or your prop. valve. going bigger is better.
Old Jun 14, 2007 | 08:15 AM
instructor74's Avatar
also make sure the slide pins on the rear brakes are not working right and not seized. As already asked di you change over the front brakes to the larger ex/si size also and the proportioning valve might also help some
EGLUVN's Avatar
Default Re: 92 CX With Rear Disc Problem (Dickies_N_FlipFlops)
ya. they feel the same as when i had rear drums. didnt feel any more stopping power. And just curious. Where is the porp valve. And is it actually a combination valve?
Old Jun 14, 2007 | 09:04 AM
Relic1's Avatar
Default Re: 92 CX With Rear Disc Problem (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">without going bigger in the front this is common. go bigger in the front and you will see the difference. the front brakes is what takes the majority of the pressure of stopping a car&gt;&gt;&gt; hence why front brakes are bigger than the rear in almost every car.</TD></TR></TABLE>
going rear disk with the smaller fronts is almost pointless. Upgrade the fronts if you want more stopping power.
the prop valve is in the center of the firewall behind the intake manifold, with 6 lines running from it.
Old Jun 14, 2007 | 09:30 AM
EL Vap133's Avatar
Default Re: 92 CX With Rear Disc Problem (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">
going rear disk with the smaller fronts is almost pointless. Upgrade the fronts if you want more stopping power.</TD></TR></TABLE>
Agreed, when you upgrade to front bigger brakes you might want to get a bigger MC & BB too, you will then notice a big difference.
Old Jun 14, 2007 | 02:28 PM
EGLUVN's Avatar
Default Re: 92 CX With Rear Disc Problem (EL Vap133)
thanks guys. Im surprised someone actually helped me on here
Terrible One
Mar 1, 2009 04:46 PM
Techy
Jan 22, 2009 08:42 PM
SneezinCD5
Jun 2, 2007 02:41 AM
LudeHatchH22a
Oct 20, 2003 12:11 AM
