Front LCAs with swaybar vs. without
On 5th gen, trims CX,DX, VX and LX does not come with front swaybars, whereas trims, EX and Si does come with front swaybars.
Would I still be able to put swaybars on the LCAs that does not come with one?
I noticed that there are two different part # on the LCAs between the two.
You will need the inner lower control arms from the SI or EX models. Plus all of the proper mounting hardware for the sway bar. And the sway bar as well.
Check your
[Modified by SLPR, 6:21 AM 6/5/2002]
Check your
susp techniques sells a kit for cars that dont have holes in the LCA's...saves some money. its like 235 from summit. fron and rear kit
[Modified by JaeOne3345, 3:05 PM 6/5/2002]
C M S
May 25, 2004 04:31 PM
Takeoff
10
Dec 21, 2003 06:59 AM
