Fixing temperature gauge?
On my cluster my temp gauge is stuck and will not go back down when i turn off the car. does anyone know how to fix this problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r »</TD></TR><TR><TD CLASS="quote">what am i looking for? if its there or what. </TD></TR></TABLE>
youre making sure its connected.
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">
youre making sure its connected.</TD></TR></TABLE>
check to see if it's loose or corroded
will check in the morning, but there shouldnt be a problem with it. since i worked before. i put back in my usdm cluster and the temp gauge on it doesnt work. but when i had the jdm cluster in it worked. the temp gauge on my usdm one worked, it went up but the temp needle wont go down.
yep juss checked the yellow wire and everything is there. and i made sure nothing loose. so im guessing its the needle on the cluster itself. anyone know how to adjust it or make it work.
igo4bmx
278
Feb 25, 2019 01:08 PM
