Fixing temperature gauge?
On my cluster my temp gauge is stuck and will not go back down when i turn off the car. does anyone know how to fix this problem?
Re: Fixing temperature gauge? (vi3tromanc3r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vi3tromanc3r »</TD></TR><TR><TD CLASS="quote">what am i looking for? if its there or what. </TD></TR></TABLE>
youre making sure its connected.
Re: Fixing temperature gauge? (numbnuts22715)
.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">
youre making sure its connected.</TD></TR></TABLE>
check to see if it's loose or corroded
will check in the morning, but there shouldnt be a problem with it. since i worked before. i put back in my usdm cluster and the temp gauge on it doesnt work. but when i had the jdm cluster in it worked. the temp gauge on my usdm one worked, it went up but the temp needle wont go down.
Re: (vi3tromanc3r)
yep juss checked the yellow wire and everything is there. and i made sure nothing loose. so im guessing its the needle on the cluster itself. anyone know how to adjust it or make it work.
igo4bmx
278
02-25-2019 01:08 PM
