zc bearings
Old Jun 13, 2007 | 08:00 PM
boosted 95 coupe's Avatar
Default zc bearings
can i use any sohc d series bearings in a zc?this is what i have been told is the reason i am asking.if not what all can i use?any other engines interchange?
Old Jun 13, 2007 | 08:34 PM
hondasaurusrex's Avatar
Default Re: zc bearings (boosted 95 coupe)
from my experience d16a6 bearings worked just fine....i went with clevite 77's and they fit just nicely
Old Jun 14, 2007 | 06:56 AM
Default Re: zc bearings (hondasaurusrex)
ya see i would think any of them would work.
Old Jun 14, 2007 | 07:06 AM
SIred91's Avatar
Rainman
You can't just go slappin bearings in there and have everything be fine though.....
Make sure you guage everything and get the right size.
Old Jun 14, 2007 | 07:11 AM
driveahonda's Avatar
94-95 Civic EX muffler bearings are the same size as zc crank bearings.
Old Jun 14, 2007 | 08:20 AM
Default Re: (driveahonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by driveahonda &raquo;</TD></TR><TR><TD CLASS="quote">94-95 Civic EX muffler bearings are the same size as zc crank bearings.</TD></TR></TABLE>
not funny jackass.......
Old Jun 14, 2007 | 09:12 AM
Default Re: (boosted 95 coupe)
well obviously your not going to go buy a set of bearings and just slap them in there and expect everything to be ok....you need to measure your crank journals and make sure you get the proper thinkness bearings
Old Jun 14, 2007 | 02:45 PM
hondaboy90's Avatar
Default Re: (hondasaurusrex)
i used d16a6 bearings in my ZC and it all plastigaged right
well i figured since this was the site thast everybody knew everything on then someone would know.i guess not.sorry for asking.if i was just going to buy a set of bearings and slap them in there then i would allready done that by now.i was just asking before i spent money on bearings just to get measurments off of.
Old Jun 15, 2007 | 07:21 AM
its not that we dont know a lot, its just when it comes to each individual engine, you never know if the crankshaft has been machined before you got your hands on it, it could have spun a bearing in the past.....
however, D16a6 bearings, both rod and main's, WILL work...you just need to measure the crank to see if you need standard thinkness, or increased thickness because of the crank being machined in the past
Old Jun 16, 2007 | 07:28 AM
why measure the crank?when you get oversized bearings it will say how bigger they are on the back side of the bearing.......my question wasnt asking about oversized bearings to begin with it was asking id any other d series bearings would work and if they would which ones would.
johnjw
Feb 12, 2010 01:30 PM
johnjw
Feb 7, 2010 06:18 AM
90EFcivicsi
16
Jan 29, 2007 10:02 PM
217sportcompacts
Aug 31, 2006 04:25 AM
travis_118
Mar 24, 2002 12:03 AM
