will 92-96 knuckle assemblies fit on a 90-97 accord
the reason i am asking this is i want to convert to conventional style rotors on my vigor and i already know 90-97 accord parts will fit but after extensive searching there is nothing on compatibility between the 2
92-94 vigor . conventional meaning 2 set screws holding them to the hub as opposed to being bolted in from behind the hub
not sure about the vigor set up, but do a search for "rotor over hub conversion", this has been covered many times for the accords.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SearchBeforeUPost! »</TD></TR><TR><TD CLASS="quote">do a search for "rotor over hub conversion", this has been covered many times for the accords. </TD></TR></TABLE>
or just go into the FAQ, there are links in there
actually i was looking to get the whole setup from a junk yard and just put new rotors on. for since i really despise doing rotors and bearings when they're severely rusted in there
if your looking for a straight bolt up application, look for a 97-98 Acura 2.3CL. It must be a 2.3CL because the 3.0 uses a 5lug set up. You can swap the 3.0 knuckels on, but then you are left with 5lug fronts, and 4 lug rears......
i compared the pictureof the 2 and on the cl/odyssey/accord the tie rod mount is high and the vigor is low does that make a big difference ??
You cant use accord/odyssey/cl knuckles because the spline count on the hub is diffrent. Also, the tie rod hole is too low, and it will blow the inner tie rods. ( I misred your first post, I thought you had an accord, and wanted legend knuckels.)
fwd0wns
Aug 3, 2012 08:29 AM
732xghost
May 30, 2009 05:33 PM
