Testing for LSD?
Old Jun 13, 2007 | 04:24 PM
deathofadam's Avatar
Default Testing for LSD?
Is it possible to check for LSD by spinning the wheels? Someone told me that I can spin one wheel forward and if the other spins in the backwards, then I don't have LSD. Can anyone verify this? Thanks!
Old Jun 13, 2007 | 04:52 PM
si90rex's Avatar
Default Re: Testing for LSD? (deathofadam)
they should both spin the same direction or do a burn out and look to see if theres one or 2 marks, or look in the diff where the axles go in if theres a bar running across the axle hole then its not lsd!
Old Jun 13, 2007 | 05:01 PM
Crx Jimmy's Avatar
Yes, the easiest way is to pull out an axle and look inside with a flashlight. If you see a bar going through its an open diff(no lsd) if you can see clear through to the other axle you have a lsd
Old Jun 13, 2007 | 05:41 PM
imgoingforit's Avatar
Default Re: Testing for LSD? (Crx Jimmy)
If you have LSD you should be more concerned about that giant koala flying overhead
Old Jun 13, 2007 | 05:43 PM
Crx Jimmy's Avatar
Default Re: Testing for LSD? (imgoingforit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by imgoingforit &raquo;</TD></TR><TR><TD CLASS="quote">If you have LSD you should be more concerned about that giant koala flying overhead </TD></TR></TABLE>
Old Jun 13, 2007 | 05:49 PM
janz3n's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the easiest way is to pull out an axle and look inside with a flashlight. If you see a bar going through its an open diff(no lsd) if you can see clear through to the other axle you have a lsd</TD></TR></TABLE>
lol how is that the easiest way? that involves jacking the car up, pulling the axle and then topping up the tranny fluid.
lol
Old Jun 13, 2007 | 06:39 PM
team-savage's Avatar
oh no! i though i had an lsd. i can't get my axles out right now a prybar isn't doing anything. but if i spin one axle the other spins the opposite way, that means i have no lsd!
Old Jun 13, 2007 | 06:45 PM
Crx Jimmy's Avatar
Default Re: (team-savage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team-savage &raquo;</TD></TR><TR><TD CLASS="quote">oh no! i though i had an lsd. i can't get my axles out right now a prybar isn't doing anything. but if i spin one axle the other spins the opposite way, that means i have no lsd! </TD></TR></TABLE>
Most likely you have no LSD,
Old Jun 13, 2007 | 06:47 PM
wow that pisses me off really bad 'cuz i've waited for this tranny for 5 1/2 months. now i want to hurt an infant
Old Jun 13, 2007 | 07:51 PM
snowseeker's Avatar
my tires spin oposite ways on my lsd car on a jack but spins both at the track or on the street.
OBX by the way
I have seen the same with Quaife and kaaz.
It all depends on how tight the spring washers are set up.
Old Jun 13, 2007 | 08:02 PM
okay now i'm not certain. to check for an lsd do i also have to take out the half shaft on the driver side?
Old Jun 13, 2007 | 09:53 PM
sanimalp's Avatar
$cat /dev/urandom
no, you can do it by only taking out one. you just have to look in there from one side or the other. the bar is big, so with a flashlight or shoplight, you wont miss it.
Old Jun 13, 2007 | 10:07 PM
k confirmed as not being lsd. now i'm really pissed.
Old Jun 13, 2007 | 10:10 PM
djphonics's Avatar
Spin one wheel forward, and if you start spinning backwards, you are on LSD.
Sorry, couldn't help myself.
Old Jun 14, 2007 | 01:24 AM
Default Re: (djphonics)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djphonics &raquo;</TD></TR><TR><TD CLASS="quote">Spin one wheel forward, and if you start spinning backwards, you are on LSD.</TD></TR></TABLE>
lol
Ok, so I will assume I don't have it. I wish i had known that when I bought the car...
Old Jun 14, 2007 | 03:06 AM
~sp33~'s Avatar
EFB055
Just chuck a burnout already
Old Jun 14, 2007 | 09:17 AM
snowseeker's Avatar
Default Re: (~sp33~)
obx is 325 on ebay.
Old Jun 14, 2007 | 09:46 AM
obx's are the ones known to bind the axles aren't they.
Old Jun 14, 2007 | 09:54 AM
mra4886's Avatar
just go out and pull the ebrake then just dump it and do a nice burn out if you smoke both tires you have it. or if you leave two tire marks you have it. if only one then you dont. thats the easiest way of checking.
Old Jun 14, 2007 | 11:06 AM
not if the engine isn't in the car. -
Old Jun 14, 2007 | 11:08 AM
mra4886's Avatar
yeah you right. so go ahead and drop it in and do just like stated above.
Old Jun 14, 2007 | 01:51 PM
that_vtec's Avatar
Default Re: (mra4886)
sounds like you got jipped......im for hire if you need to see some magic if you know what i mean.......like you know make someone disappear.
Old Jun 14, 2007 | 02:41 PM
liquidoblivion's Avatar
Default Re: (that_vtec)
I don't know why you guys keep suggesting burnouts. A open diff can leave two black marks all day long. If you really want to test by spinning the tires you will have to get one tire on some loose or slick surface. If that tire spins and the other one doesn't move then you have an open diff. Open diff will send all the power to the wheel with the least resistance, so if both wheels are on grippy asphalt or concrete both will probably spin, you will need to get one on a slick surface and keep the other one on a grippy surface to really tell.
Old Jun 14, 2007 | 03:35 PM
Default Re: (liquidoblivion)
I bought the car with the engine already, and he told me it had lsd. I swear I even remember seeing LSD stamped on the tranny, but it isn't so I must have been dreaming or maybe on lsd... Now I wonder if it even has the type r cams he said were installed...
Old Jun 14, 2007 | 05:09 PM
I CRX I's Avatar
cant he just remove one axle, then try and drive the car a few feet? from what i was told, only an lsd trans would actually move the car foward
