what radiator hose do i need?
ihave a 97 civic hatch cx and i have stock radiator and i swaped in a b16a2 from a 99 si
i got a used hose which was stupid of me and now itss come back to kick me in the *** because it now has a leak.
so im going to buy a brand new hose i dont know what brand yet not spoon to expensive for me
please help me out i need to know asap
you need 94-95 del sol VTEC hoses, basically, its basically your car the way it sits now. B16a from the factory. the radiator is identical except that the del sol vtec radiator is a little thicker 2 core design, if you arent having overheating issues then the radiator swap wont do you a bit of good so dont waste the money.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schardbody »</TD></TR><TR><TD CLASS="quote">you need 94-95 del sol VTEC hoses, basically, its basically your car the way it sits now. B16a from the factory. the radiator is identical except that the del sol vtec radiator is a little thicker 2 core design, if you arent having overheating issues then the radiator swap wont do you a bit of good so dont waste the money.</TD></TR></TABLE>
Wrrronnnggggggggggggg.
You need the stock 99-00 Si hoses, and you need a Del Sol VTEC radiator. There is no stock hose that will fit the stock inlets/outlets on the B16A and then fit the 1-1/8" inlets/outlets on the SOHC Civic radiator. The 99-00 Si and Del Sol VTEC have 1-1/4" inlets/outlets on the radiator.
Here's the radiator you need:
http://www.radiatorbarn.com/s7...=1.6L
The other option is to buy some T-Bolt clamps and just wring the **** out of your hoses .... but I've still seen that leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
The other option is to buy some T-Bolt clamps and just wring the **** out of your hoses .... but I've still seen that leak.</TD></TR></TABLE>
oh yeah, thats right, but most people just tighten the **** out of the hose clamps.
Cedrickyle
12
Sep 1, 2016 01:24 PM
Shoot0
Nov 20, 2010 04:28 PM
ForgetMyNameX07
Nov 7, 2008 06:29 AM
delsolrob
10
Apr 27, 2004 08:57 PM
SpoonSportsJunkie
Sep 9, 2002 06:39 AM
