92 Accord Main Relay placement
Old Jun 13, 2007 | 11:56 AM
treeline's Avatar
Default 92 Accord Main Relay placement
Could any of you good hearted people tell me where it is? I have got a new one to put in but am at a loss.....!
Thanks....
Old Jun 13, 2007 | 01:04 PM
693's Avatar
693
Default Re: 92 Accord Main Relay placement (treeline)
driver side under dash i think its on the right side upper
Old Jun 13, 2007 | 01:41 PM
treeline's Avatar
Default Re: 92 Accord Main Relay placement (693)
Thank you on the way....I looked there and it was not like the picture in another thread....will look some more.....!
Old Jun 13, 2007 | 01:50 PM
treeline's Avatar
Sorry, I looked....any other idea...?
Old Jun 13, 2007 | 06:52 PM
SteveoBA8's Avatar
Should be in the area
Old Jun 14, 2007 | 02:50 PM
dude_123's Avatar
Default Re: 92 Accord Main Relay placement (SteveoBA8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 &raquo;</TD></TR><TR><TD CLASS="quote">Should be in the area
Yes, that is the location, but a module will be in the way that blocks the view of the main relay. Take off the module then the main relay will be easily accessible.
Old Jun 14, 2007 | 06:21 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: 92 Accord Main Relay placement (dude_123)
http://techauto.tripod.com/mainrelay.htm
all you ever wanted to know about honda main relays and more
Old Jun 21, 2007 | 10:38 AM
ali habim's Avatar
main relay is located l/s of steering colum top of dash. if you have cruise contol the control unit will have to be removed. relay is located above unit. 2 10mm bolts, let hang and change relay . hello hello this is habim
Old Jul 3, 2007 | 10:12 AM
crayzed_weasel's Avatar
Just finished replacing the relay on my 93 accord lx
For those with manual transmissions, be prepared to wrestle the relay past the clutch interlock switch. Once the relay has had the nut holding it in place removed, you have enough wiggle room to pull the clutch interlock connector, which in turn makes enough room to pull the relay. Giant pain in the keister, really. I'd also recommend locating a "deep" 10mm socket for said nut.
Old May 21, 2011 | 06:33 AM
mid_life_crisis's Avatar
Sorry for doing the zombie number on this thread, but I want to make sure I know what I'm looking at.
Lying on my back under the dash, just to the right (toward driver's side door) of the steering column is a grayish metal module held in place by what looks like four ten millimeter nuts. One is also holding a small relay in place. Is the Main Relay behind this module?
While I'm here, will that relay prevent the engine from cranking at all? Clicking sounds and what sounds like electrical arcing to me but no engine turning at all.
Old May 23, 2011 | 10:43 AM
90efhatch's Avatar
that does not sound like the main relay to me, sounds more like the starter is bad.
Old May 24, 2011 | 12:30 PM
frankenghia's Avatar
or even a bad ground...
Old May 24, 2011 | 05:58 PM
fcm's Avatar
fcm
Old Fart
Locations... http://techauto.tripod.com/mainrelay.htm
The PGM-FI Main Relay has nothing to do with the starter.
If engine does not crank, try a bypass jump, unplug the starter lead from the starter motor, make sure car is not in gear, use a jumper lead and supply power directly to the terminal you unplugged the starter lead from, you can jump from the batt. pos.(+) post or the batt. cable post on the starter.
If the bypass jump works, the starter or starter solenoid is not the problem, I would look at the ign. switch, the starter relay or CIL switch or A/T gear position switch on automatics, also if it is an automatic, try starting in neutral. 94
Old Aug 31, 2013 | 09:27 AM
JAChondia's Avatar
Is their a way to test the main relay
Old Aug 31, 2013 | 09:55 AM
JAChondia's Avatar
seanblais
Jul 31, 2013 12:15 AM
ZellaM
Feb 8, 2010 04:39 PM
turbostd
Oct 3, 2007 12:19 PM
92 white eg
Aug 6, 2007 09:22 AM
shrug
10
Oct 13, 2006 08:07 AM
