B16a2 ecu code 21
Old Jun 13, 2007 | 06:49 AM
calgarycrx's Avatar
Default B16a2 ecu code 21
Newbie here so go easy on me...
Ok so I got a ecu code of 21 which is referencing to the vtech solenoid and I did do a search but cant find any info as to what causes this and how bad is this... Easy fix?
Please forgive my ignorance as I am not super savvy in this department.
Thanks in advance,
Old Jun 13, 2007 | 07:37 AM
92_civic's Avatar
Default Re: B16a2 ecu code 21 (calgarycrx)
check for power at the vtec solenoid with the ignition switch on, if that is good, remove the vtec solenoid and check the screen for metal/debris that could be blocking oil flow...if both of those things check out good, I'd swap the vtec solenoid with a known good one and re-check
Old Jun 13, 2007 | 07:41 AM
calgarycrx's Avatar
Default Re: B16a2 ecu code 21 (92_civic)
thank you sir...
Is this quite common?
Old Jun 19, 2007 | 08:22 AM
92_civic's Avatar
no...I've only ever changed one
Old Jun 19, 2007 | 01:02 PM
Relic1's Avatar
if it's a swap make sure you ran the VTEC solinoid wire correctly.
if this is an existing car that has been running without this code and you didn't change anything prior to this code then double check all the electrical connections and the screen like 92_civic mentioned.
make sure your thermostat ground is clean and not loose as well as probe the solinoid wire for resistance to ground.
Old Jun 19, 2007 | 03:01 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (Relic1)
https://honda-tech.com/zerothread/1812135
Jdmkids Manny
17
May 12, 2016 02:18 PM
ek4_b16a
Apr 15, 2009 03:43 PM
racereaper7
Aug 14, 2007 08:56 AM
Mentat Ghola
May 15, 2003 10:15 PM
Hondasaurs
May 5, 2003 03:00 PM
