sound comming from tranny, help
Old Jun 12, 2007 | 08:32 PM
JDM-Punk's Avatar
Default sound comming from tranny, help
ok so im looking at buying a eg hatch si and it has about 160k miles on it so stuff is a bit old, and when i test drove it the guy said a friend told him his pilot bearing is going bad, but not sure if thats it cuz ive heard that wouldnt be the source... but anyways test drove it, engaged gears fine from the way it seemed no slippin or grinding but when i layed off the gas in 1st it made a rubbing/ hittin sound and when in a gear i could do a little circle with the shifter in almost every gear, felt kinda like if their was play between where the shifter and the shifter arm met... and it was a stock clutch and stock shifter and he said hes never had tranny probs... not sure what to search that under so help would be nice, thanks
Old Jun 12, 2007 | 08:58 PM
JDM-Punk's Avatar
ohh and they said it had a stock exhaust just put on and think the guys that put it on half ***'d it and think the exhaust might be rubbing against stomething and that could be the source of the prob... this is all from them not me
Old Jun 12, 2007 | 09:22 PM
dannis.'s Avatar
Default Re: (Slo-EG1)
i don't think its the exhaust rubbing anything because then you would have very little play and a harder time putting it in gear. to me it sounds like your throw out bearing is shot.
Old Jun 12, 2007 | 09:25 PM
JDM-Punk's Avatar
k, yea they said that it prob is the throw out bearing, but they added that the exhaust might be rubbing against something and wouldnt help the sound... but yea i know about the rubbing against the shifter, not to mention it would get hot after awhile... but yea thanks for the help
Old Jun 12, 2007 | 09:35 PM
dtapia's Avatar
they were nortious for main shaft bearings in the trans.
Old Jun 12, 2007 | 10:29 PM
ridin98civic's Avatar
Default Re: sound comming from tranny, help (Slo-EG1)
sounds like the noise my input shaft bearing made.
Old Jun 12, 2007 | 10:52 PM
JDM-Punk's Avatar
thanks for the help peoples
shaundesjardins
19
Jul 26, 2012 11:54 AM
hondatuner20
18
Jan 28, 2006 09:47 AM
stRodda
Sep 12, 2003 04:25 PM
twkdCD595
Apr 7, 2003 09:02 AM
JM Performance
Jun 3, 2002 03:59 AM
