92-95 civic dx trim to cx trim
Old Jun 12, 2007 | 06:44 PM
Shaun's Avatar
Default 92-95 civic dx trim to cx trim
has anyone change the trim meaning the side moldings to a cx, meaning filling in or some how deleting the side moldings, if so how did you do it, and how is it working out? I just bought a dx hatch , and would like to fill in the moldings to make it look like a cx
Old Jun 12, 2007 | 06:47 PM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
Default Re: 92-95 civic dx trim to cx trim (Shaun)
I prefer the CX look as well. Hybridkoop shaved his on the coupe project.
https://honda-tech.com/zerothread?id=1541141
Old Jun 12, 2007 | 06:49 PM
Shaun's Avatar
nice
Old Jun 13, 2007 | 01:04 PM
Shaun's Avatar
anyone esle?
Old Jun 13, 2007 | 02:01 PM
jdmjeff's Avatar
Default Re: (Shaun)
take off the mouldings (duh) grind down the holes till metal shows then knock them in slightly. then weld them up, then bondo them up. thats really the only secure way to do it. Then tight wipe the hole moulding and find a block that fills up the place that you just wiped and block it straight. its kinda a pain the butt so it might take a couple priming to get it lookin straight
Old Jun 14, 2007 | 06:46 PM
Shaun's Avatar
Default Re: (jdmjeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">take off the mouldings (duh) grind down the holes till metal shows then knock them in slightly. then weld them up, then bondo them up. thats really the only secure way to do it. Then tight wipe the hole moulding and find a block that fills up the place that you just wiped and block it straight. its kinda a pain the butt so it might take a couple priming to get it lookin straight </TD></TR></TABLE>
(duh) ? i know how its done... just wanted feedback
Old Jun 17, 2007 | 02:25 PM
jdmjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">has anyone change the trim meaning the side moldings to a cx, meaning filling in or some how deleting the side moldings, if so how did you do it, and how is it working out? I just bought a dx hatch , and would like to fill in the moldings to make it look like a cx </TD></TR></TABLE>
parden me but you stated above "HOW DID YOU DO IT" but correct me if im wrong. if you wanted a cx, vx you should have bought one
Old Jun 17, 2007 | 02:51 PM
Shaun's Avatar
Default Re: 92-95 civic dx trim to cx trim (jdmjeff)
parden me but you stated above "HOW DID YOU DO IT" but correct me if im wrong. if you wanted a cx, vx you should have bought one </TD></TR></TABLE>
yeah.... but why the smart *** comment .......... anyway my question is answered!!!
Old Jun 17, 2007 | 04:34 PM
94eh2's Avatar
i did this to my dx hatch..heres wat i did first i removed the moldings..then i grinded down all around the holes..after that i took some cloth and fiberglass resin and applied it to the holes after i le tit dry i went ahead and covered the holes with light weight filler..i continued to sand add more filler prime ect.....and a little puty overall it came out nice and has since been holding up with no problems i dont care what anyone says..now if you have acess to a welder than weld them obviously it will be the best method but if you are like me who didnt have acess to a welder my method works fine..hope i helped
Old Jun 17, 2007 | 05:01 PM
jdmjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shaun &raquo;</TD></TR><TR><TD CLASS="quote">yeah.... but why the smart *** comment .......... anyway my question is answered!!!</TD></TR></TABLE>
the (duh) wasnt pointed in your direction neways.... it was from future comments that whould sound like "i know to take off the side mouldings" so bump
Old Jun 17, 2007 | 05:43 PM
Shaun's Avatar
Default Re: 92-95 civic dx trim to cx trim (305accord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 305accord &raquo;</TD></TR><TR><TD CLASS="quote">i did this to my dx hatch..heres wat i did first i removed the moldings..then i grinded down all around the holes..after that i took some cloth and fiberglass resin and applied it to the holes after i le tit dry i went ahead and covered the holes with light weight filler..i continued to sand add more filler prime ect.....and a little puty overall it came out nice and has since been holding up with no problems i dont care what anyone says..now if you have acess to a welder than weld them obviously it will be the best method but if you are like me who didnt have acess to a welder my method works fine..hope i helped</TD></TR></TABLE>
thanks!!
the (duh) wasnt pointed in your direction neways.... it was from future comments that whould sound like "i know to take off the side mouldings" so bump</TD></TR></TABLE>
np
Old Jun 17, 2007 | 06:36 PM
94eh2's Avatar
no problem
tncivic-dvsb
13
May 27, 2006 12:15 PM
dispnoiracer
May 1, 2006 09:49 AM
vi3t_dude
33
Feb 20, 2005 12:14 PM
B2FiNiTY
Apr 24, 2002 01:02 PM
