OMG !!! SAME problem ... HELP !!!
Old Jun 12, 2007 | 06:31 PM
RMX_EF9's Avatar
Default OMG !!! SAME problem ... HELP !!!
Well, I made a previous thread about my car being in first gear, no-matter what ! I changed out the transmission, brand new clutch ... the works ... AND STILL my car thinks it's in first gear ... WTF ??? HELPPPPPPPPP !!!!!
A buddy of mine thinks its the shift linkage ...
Old Jun 12, 2007 | 07:01 PM
RMX_EF9's Avatar
Default Re: OMG !!! SAME problem ... HELP !!! (RMX_EF9)
anyone ??? I'm on a time budget ...
Old Jun 12, 2007 | 07:13 PM
EFinawesomeman's Avatar
Gremlins. they hate some people.
Old Jun 12, 2007 | 07:22 PM
RMX_EF9's Avatar
Default Re: OMG !!! SAME problem ... HELP !!! (EFinawesomeman)
Yea they do ... lol.
Old Jun 12, 2007 | 07:31 PM
whats the entirety of the problem my man? does it go in and out of gear or it just stays stuck in 1st?
Old Jun 12, 2007 | 07:34 PM
RMX_EF9's Avatar
well, ... No matter what position the shifter is in, it's always in first ... after I changed out the tranny today, I thought everything was going to be cool, but again, it's still in first gear ... I can put the shifter in neutral and let off the clutch, and it being in "first", will stall out ...
Old Jun 12, 2007 | 07:36 PM
DenzComp's Avatar
You're sure everything is connected in the linkage?
Old Jun 12, 2007 | 07:38 PM
RMX_EF9's Avatar
Default Re: (DenzComp)
I pretty sure ... linkage is attached at the tranny, both parts, torque bar and shifter link, spring pen is in the linkage attaching the tranny to the linkage ...
Old Jun 12, 2007 | 07:42 PM
Default Re: (RMX_EF9)
where do you live?
Old Jun 12, 2007 | 07:45 PM
DenzComp's Avatar
Have you checked the actual shift lever itself? Maybe the bolt fell out of the bottom.
Old Jun 12, 2007 | 07:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DenzComp &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked the actual shift lever itself? Maybe the bolt fell out of the bottom.</TD></TR></TABLE>
I have a hunch it could just be your old shift lever it self. have you checked if anything could be blocking it at all? does it just feel as if it is stuck there? have a friend check underneath while you pull it in and out of gears to see if its all aligned up right and if the lever is just broken, i've honestly never heard of a problem like this.
Old Jun 12, 2007 | 07:59 PM
Tippyman's Avatar
Default Re: (EFinawesomeman)
Do you have a B-series swap and perhaps did not lengthen or shorten the linkage the right amount?
Old Jun 12, 2007 | 09:54 PM
.Manny.'s Avatar
Touching My Member
Default Re: (Tippyman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a B-series swap and perhaps did not lengthen or shorten the linkage the right amount?</TD></TR></TABLE>
hhhhhhhmmmmmmmmmm.......
Old Jun 13, 2007 | 09:29 PM
RMX_EF9's Avatar
Default Re: (.Manny.)
well ... I'm back after another day of turning up nothing ...
I am not running a b16 ... just a stock D15, FTW ...
I dropped the gearshift down and disconnected it from the car ... disassembled the whole thing and put it back together ... looks fine to me, everything in mechanical order, nothing to block it ... STILL, with the shifter in neutral, it Thinks it's in first ... I could drive off in neutral, 3rd gear,forth gear and reverse all work fine, while in those gears letting off the clutch, I will stall out like I'm supposed to ... STILL cannot get the shifter to unlock 2nd,5th ... when I put the shifter in first, the motor bogs down real heavy ... but letting off the clutch in first WON'T stall it out ... I'm still confused !! When I changed out the tranny, I DIDN'T take the clutch off the block ... is that maybe what it could be, or still the the shift rods ???? I really need my car to work, Im **** poor at the moment and can't get anywhere I need to go ... Class, work, nothing !!
Old Jun 13, 2007 | 09:59 PM
crx22's Avatar
Does it feel like its going into the gears?
I mean when you put it in first does it feel like it goes into the gear...same with 2nd on up?
Old Jun 13, 2007 | 10:01 PM
.Grimace's Avatar
footwork mastery
Default Re: (crx22)
just get new shift linkage? it's super cheap if not free...
Old Jun 13, 2007 | 10:04 PM
RMX_EF9's Avatar
Default Re: (Gremice)
When I put it in first, it's like theres no gear there ... Just slides right up in first, with a moderate amount of side 2 side play, and 2nd gear ? I can't get the gearbox to even recognize that theres a slot for second gear, same for 5th also ... I'm so frustrated and worried ... 3rd, 4th and R all seem to go into gear, sometimes giving me alot of hell to get them into gear ... sometimes not ...
Old Jun 13, 2007 | 10:20 PM
NuMMbNuTtS's Avatar
can you get into all the gears while the engines not running?
at first said you got a new clutch, then later claimed you never took the clutch off the block when you changed trannys. Its possible that something with the clutch can be broken and not letting off when you hit the pedal, causing you to not be able to switch gears while running.
have you also tried adjusting the clutch cable
Old Jun 14, 2007 | 06:16 AM
DenzComp's Avatar
Default Re: OMG !!! SAME problem ... HELP !!! (NuMMbNuTtS)
Try going into gears without pressing the clutch at all.
If it doesn't grind then you'll know it isn't even making it to the tranny...
If it does..you know it's working that far...
Probably not the most bright idea, but I just figured that would be a way to test one other thing.
Old Jun 14, 2007 | 06:29 AM
JLefevers's Avatar
Default Re: OMG !!! SAME problem ... HELP !!! (DenzComp)
i would say check the clutch like stated above and also check your clutch cable
Old Jun 14, 2007 | 08:51 AM
RMX_EF9's Avatar
BUMP !!! ...
Old Jun 14, 2007 | 09:06 AM
IT GUY's Avatar
I've seen lowered cars bottom out and bend shift linkages.. usually the result is not going into and/or not coming out of gear.. it may not be super obvious, but it might look are tore up..
if you need another d15 linkage, I've got one you can have for just shipping cost
Old Jun 14, 2007 | 09:31 AM
RMX_EF9's Avatar
Default Re: (IT GUY)
Whats your Email Add. ?
Old Jun 14, 2007 | 09:11 PM
RMX_EF9's Avatar
ok ok ok ... little progress today ... dropped out the second tranny, and now the third tranny is in the car ... the linkages are hooked up, tranny on the block, and when I went through the gear shift motions, everything seems ok, wont know till morning when I throw the axles and blah blah blah back on ... I could access every gear !
Question though ... even though I can access all the gears, im a little worried is still going to do me wrong and still be stuck in a gear no matter what ... Any odds of that happening now that the shift box can actually access all the gears ?
Old Jun 14, 2007 | 09:34 PM
cr-x-91's Avatar
i would replace the shift linkage.....if it doesnt go ur way..
