Low rpm shutter, or miss (b16 crx)
I have been having a problem that seemed to get worse all of a sudden. I use to have a low rpm shutter from 1k-2k and before or after I would have no problems, but now it seems like it can happen at anywhere from 1k-5k..
I the shutter/miss only happends when I give it more then 1/4 throttle. If I'm real light on the throttle it will not shutter, but if I mash it the car will bog/miss over all just run bad.
Parts replaced so far have been; fuel filter, and fuel rail. To no avail.
I also have a problem when starting it. The motor boggs and stalls randomly after I have been driving for any amount of time. Then it feels flooded and I have to wait for a while before it will start again, then it will start right up with no probems (other then the shutter
). Its the same problem as this guy.
https://honda-tech.com/zerothread/2012392
Set up;
1988 crx si: jdm B16a, exedy s1 clutch, plugs/wires, AEM fuel rail, DC header, stock exhaust, ebay high flow cat, hasport mounts.
Problem child shot
). Its the same problem as this guy.https://honda-tech.com/zerothread/2012392
Set up;
Problem child shot
just a hella n00b question. actualy ive just never felt it. how hard do the jdm b16s pull stock?
are you guys satisfied with them for street cars and what are some track times in ef/crxs.
Dizzy does sound like the culprit.
Have you popped your plugs out and looked at them? I always like to start cheapest easiest way first.
Kevedge
17
Aug 13, 2004 10:19 AM
