Custom dp for gt turbo
Old Jun 12, 2007 | 05:17 PM
Desir Performance's Avatar
Default Custom dp for gt turbo
quick question im a Iron worker and in the building that im working in there's a **** load of electrical Conduit pipe in different sizes, i was wondering have any body tried to use this stuff for making an exhaust or down pipe? The only flaw that i saw on the pipes was that they were covered in galvanize. Is there a weight difference between conduit pipe and say ms, ss? please some one let me know cause my buddy can get me a 6' pipe in any size i want, they even have a 6'' piece lol
Old Jun 13, 2007 | 12:58 AM
GTiR NX's Avatar
Default Re: Custom dp for gt turbo (Desir Performance)
Exhaust pipe is tubing, Conduit is tubing, same stuff really as normal exhaust pipe just a slightly lighter gage some times.
Just grab a chunk measure the OD if its called/ labeled 2" and measure the same as its sized its tubing.
If its not the same size as its labeled its pipe. As an example 3 " pipe is really 3 3/8" to 3 1/2" OD ruffly pipe is nominal size up to 13" , 14 " and up its sized the same its OD.
Old Jun 13, 2007 | 05:29 PM
Default Re: Custom dp for gt turbo (GTiR NX)
bump for more info
Old Jun 16, 2007 | 06:55 PM
dfoxengr's Avatar
what he was trying to say is that tubing is measured as OD, so 3" tubing has a 3" OD. mild tubing is normally 1020
piping on the other hand is measured ID, and has thicker walls, and is made from 1018 mild normally. so 3" pipe is 3" ID, so the OD is bigger.
16ga. tubing, normal exhaust stuff, is .065", or 1/16th"
you need to measure the OD of what you have and the wall thickness of it.
report back here with your findings.
Old Jun 16, 2007 | 09:41 PM
Default Re: Custom dp for gt turbo (dfoxengr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dfoxengr &raquo;</TD></TR><TR><TD CLASS="quote">what he was trying to say is that tubing is measured as OD, so 3" tubing has a 3" OD. mild tubing is normally 1020
report back here with your findings.</TD></TR></TABLE>
ok got you, will do on monday.
mikeycivic
Dec 7, 2009 01:34 PM
PolishSasquatch
Welding / Fabrication
Apr 8, 2008 02:57 PM
r0yal
Apr 19, 2006 07:03 PM
CRXb18Turbo
Jan 21, 2006 06:56 AM
B16CRXT
Mar 14, 2005 02:34 PM
