Proto Parts, Turbo/Intake Manifold
Old Jun 12, 2007 | 04:37 PM
PSI2HI's Avatar
Former Vendor
Default Proto Parts, Turbo/Intake Manifold
Some prototype parts we've been workin on for Mike the salesman here's 00 civic si.
Old Jun 12, 2007 | 04:53 PM
93supercoupe's Avatar
Default Re: Proto Parts, Turbo/Intake Manifold (PSI2HI)
looks like its gonna be a sweet setup.
Is this for the street or the track?or both?
Old Jun 12, 2007 | 05:24 PM
PSI2HI's Avatar
Former Vendor
Default Re: Proto Parts, Turbo/Intake Manifold (93supercoupe)
It's a DD.
Old Jun 13, 2007 | 04:13 AM
ShawnR's Avatar
whats up with that intake manifold any dyno numbers?
Old Jun 13, 2007 | 07:31 AM
PSI2HI's Avatar
Former Vendor
Default Re: Proto Parts, Turbo/Intake Manifold (97gsrcoupe)
No, not yet. Its some prototype piece we've been working on for a few months. Still making a few changes but we should be ready to dyno/test w/in the next month.
Old Jun 13, 2007 | 08:09 AM
.RTErnie's Avatar
looks very nice Nick! keep up the good work
Old Jun 13, 2007 | 08:10 AM
JDMs1eeper's Avatar
Something I really like about you guys is, you’re always stepping outside of the box to make something different. Stuff looks nice, Good Luck w/ the numbers, should be pretty decent.
Old Jun 13, 2007 | 08:29 AM
berts95ej's Avatar
* B A N N E D *
you guys make a great product. that manifold looks sweet. are those gonna be put into production or is this a one time thing?
Old Jun 13, 2007 | 02:08 PM
ShawnR's Avatar
Default Re: (berts95ej)
any idea on a price on the intake manifold if u have good resluts?
Old Jun 13, 2007 | 02:12 PM
Andy R's Avatar
Default Re: Proto Parts, Turbo/Intake Manifold (JDMs1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMs1eeper &raquo;</TD></TR><TR><TD CLASS="quote">Something I really like about you guys is, you’re always stepping outside of the box to make something different. Stuff looks nice, Good Luck w/ the numbers, should be pretty decent.
I agree the stuff looks great and I definitely don't intend this to be negative, but i'm not really sure how this is 'outside the box'. These designs are pretty standard for custom units around the racing scene.
Old Jun 13, 2007 | 09:43 PM
Doeboy's Avatar
nice work, i hope the intake manifold makes good numbers for you. it looks to be a nice piece.
Old Jun 13, 2007 | 10:35 PM
PSI2HI's Avatar
Former Vendor
Default Re: (97gsrcoupe)
We're gonna keep @ it until we're happy w/ the results.
Old Jun 14, 2007 | 04:19 PM
PSI2HI's Avatar
Former Vendor
Old Jun 14, 2007 | 11:31 PM
djphonics's Avatar
Looks good.
'Ol Skool Pro/Engineer. I used to use 2000i^2 and 2001. What a PITA. I'll have to say SW rocks it.
Old Jun 15, 2007 | 09:45 AM
snoochtodanooch's Avatar
Full radius on the intake stacks, now that's how it's supposed to be done. ****** A
Very very nice work on the intake mani, it doesn't look super slick but it looks very well designed.
It's a shame you had to make that 1 little 1" insert between your ells on the exhaust mani, or I would have said that was great too. It's still very good, but that one little thing catches my eye as not pretty.
GOOD JOB
Old Jun 19, 2007 | 07:17 PM
PSI2HI's Avatar
Former Vendor
Default Re: Proto Parts, Turbo/Intake Manifold (djphonics)
We got wildfire 3.0
Old Jun 27, 2007 | 04:25 PM
PSI2HI's Avatar
Former Vendor
Old Jun 27, 2007 | 09:09 PM
redzcstandardhatch's Avatar
something different
very similar to what i did with my intake manifold...man did we put some time in on the cnc machine...
just did a miata one nearly identical to that too....awesome work.
my civic one (f22 engine) seems to be making amazing power....i doubt you'll be dissapointed!
Old Jun 28, 2007 | 04:58 AM
tepid1's Avatar
Default Re: (redzcstandardhatch)
Those intake manifold runners really should be tapered to increase velocity.
Old Jun 28, 2007 | 05:11 AM
Default Re: (tepid1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tepid1 &raquo;</TD></TR><TR><TD CLASS="quote">Those intake manifold runners really should be tapered to increase velocity. </TD></TR></TABLE>
will that really matter under boost? I understand the purpose and function of a velocity stack and all, but with a full radius in the manifold plenum to reduce turbulence, and I'm sure a ridiculous amount of boost pressure, i don't think the taper would matter much at all. It's under pressure already so there is turbulence everywhere anyhow. Every little bit counts though I guess.
I just don't think it's a legit critique on the nice work, and tapering the runners (if you can't find them off the shelf somewhere) would have probably required a significant increase in machine time and money. Even still, an explanation to your opinion is welcome if you want to give it.
Old Jun 28, 2007 | 09:47 PM
NativeSon's Avatar
Default Re: (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">
I just don't think it's a legit critique on the nice work, and tapering the runners (if you can't find them off the shelf somewhere) would have probably required a significant increase in machine time and money. Even still, an explanation to your opinion is welcome if you want to give it. </TD></TR></TABLE>
Making tapered runners is not a problem for a fabricator. A tapered runner will always be more efficient, due to greater velocity even under boost.
A good reason for having them, is that this is a street car. It'll spend 95% of it's life not in boost.
Now, aside from all that, I think this is still some nice fab work. I'm sure it'll work fine.
Old Jun 28, 2007 | 10:03 PM
.RTErnie's Avatar
Default Re: (NativeSon)
Len is your car EVER going to be finished or running?
Old Jun 29, 2007 | 02:47 AM
weiRtech's Avatar
OG Fabricator
i built a manifold with tapered runners and it really isn't that difficult. for this intake manifold pictured above, if the runners were formed from round pipe it would be just as easy, but if they were cut from solid billet it would be foolish to not add a taper to them to begin with since you already have to do the cutting. i cut mine from solid billet with a .5 degree taper. regardless, the manifold runners look good and i think the idea to go with oval velocity stacks is a good one as i have plans to do this for my next manifold, but i think the plenum could have been designed to flow a bit better from the tb port into the plenum.
Old Jun 29, 2007 | 05:36 PM
NativeSon's Avatar
Default Re: (.RTErnie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RTErnie &raquo;</TD></TR><TR><TD CLASS="quote">Len is your car EVER going to be finished or running? </TD></TR></TABLE>
How 'bout you pay my salary so I can spend all day in the machine shop working on my car parts?
Old Jun 29, 2007 | 06:09 PM
HiProfile's Avatar
Default Re: (weiRtech)
If you have access to solid works or some cad app, as well as a cnc machine... you sure as hell should have access to something as simple as a bandsaw As its only ~8 cuts, a quick slice down each runner, then another to cut the sliver out to make them taper, then 8 straight welds. If this was in developement for several months, 1-2 days of extra work shouldn't be an issue. BTW: http://www.velocity-of-sound.c...s.htm for the cheapness!
As for the 'who cares, it will make shittons of power anyways' attitude, you may have well just put on a gold-plated log mani. When you put this much effort into a performance part, then skimp on something relatively simple, then it tends to seem like it was done more for show than for go. Regardless, I'd still 'sell out' and run it, its still WAY better than any manifold I own
