9500rpm?
Old Jun 12, 2007 | 01:37 PM
cvccr's Avatar
Default 9500rpm?
im about to build my head that will make power up to 9200 but start dropping and i want to rev atleast to 9500 so i end up in the highest rpm possible on the next gear
im leaving the block bone stock though.
will the stock block handle 9500 occassionally??? like once a week?
Old Jun 12, 2007 | 01:45 PM
GO-FIGHT-KILL's Avatar
No.
Just remember what RPM stands for... Ruins Perfect Motors. On stock bottom end, I personally wouldn't turn past 9,000RPM. I've heard of stock R bottom ends turning to around 9,600RPM before catastrophic failure, but I would NOT push it.
I'd keep safe around 8,8000-9,000RPM until you get that bottom end built.
Old Jun 12, 2007 | 01:57 PM
cvccr's Avatar
more input
Old Jun 12, 2007 | 03:59 PM
Black R's Avatar
25 Year Member
Default Re: 9500rpm? (cvccr)
I have a stock itr bottom end, stock itr head with toda valvesprings, Ti retainers, toda timing belt, toda cam gears and toda cams (spec C).
Bolt-ons include toda itb's, and hytech header.
Tuning is with crome pro and innovate wideband.
I usually rev it to 9200, but rev limiter is set at 9500 - I posted a vid around here somewhere if you want to see it.....
I mainly autox the car although I daily drove it for three years without issue. The rev limiter I used to hit regularly at 8600 but since i've raised it, i'm able to stay off it it more.
It doesn't seem to burn any oil more than maybe 1/4-1/2qt between changes - which is what it did when the motor was stock, although i am very conscious of proper and timely maintenance.
But Go-Fight-Kill is right - if you want reliability, then don't test the rev limiter too much! Unless you're making power this high, it doesn't make sense to rev.
Modified by Black R at 11:06 PM 6/12/2007
Old Jun 12, 2007 | 04:43 PM
fastvtecCL's Avatar
Default Re: 9500rpm? (Black R)
my car also has a stock itr bottom end, stock itr head with toda valvesprings... I reved to 9700RPMS on my JRSC type R all day long with no problems
Old Jun 12, 2007 | 04:47 PM
^ Dayum.
Old Jun 12, 2007 | 05:29 PM
cvccr's Avatar
Default Re: 9500rpm? (fastvtecCL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastvtecCL &raquo;</TD></TR><TR><TD CLASS="quote">my car also has a stock itr bottom end, stock itr head with toda valvesprings... I reved to 9700RPMS on my JRSC type R all day long with no problems </TD></TR></TABLE>
damnnn. you got pm
anybody else?
Old Jun 12, 2007 | 05:31 PM
Locc's Avatar
Default Re: (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">No.
I'd keep safe around 8,8000-9,000RPM until you get that bottom end built.</TD></TR></TABLE> listen to him
Old Jun 13, 2007 | 01:41 AM
fastvtecCL's Avatar
http://videos.streetfire.net/v...2.htm
Old Jun 13, 2007 | 02:04 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">I've heard of stock R bottom ends turning to around 9,600RPM before catastrophic failure, but I would NOT push it.
umm, no. i have been running 9500 consistantly since 2001 on my stock bottom and stock head (toda cams/springs/ti retainers) with no issues.... this past weekend alone i hit the revlimiter no less then 18 times or so. so, if the motor is in good shape, i do not see why not.
Old Jun 13, 2007 | 03:58 AM
cvccr's Avatar
Default Re: (Rodney)
my engine is very very healthy. i guess ill go for it.
if the block blows, ill go 2L hope not though
Old Jun 13, 2007 | 05:58 AM
Mr.OB*GYN_Rhett's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rodney &raquo;</TD></TR><TR><TD CLASS="quote">
umm, no. i have been running 9500 consistantly since 2001 on my stock bottom and stock head (toda cams/springs/ti retainers) with no issues.... this past weekend alone i hit the revlimiter no less then 18 times or so. so, if the motor is in good shape, i do not see why not. </TD></TR></TABLE>
thats impressive
Old Jun 13, 2007 | 08:02 AM
You've got bigger ***** than me.
Old Jun 13, 2007 | 11:45 AM
Rodney's Avatar
You've got bigger ***** than me.</TD></TR></TABLE>
no, i just keep up with the maintainence on the car, so it works well.
Old Jun 13, 2007 | 01:24 PM
I hear ya'.
I keep up my maintenence too, but man, a rod through the block hurts my brain. I'm just big on fail safe operation I guess. Good to hear turning a stock bottom end that deep has worked out for you.
Old Jun 13, 2007 | 02:38 PM
Clerique's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">I hear ya'.
I keep up my maintenence too, but man, a rod through the block hurts my brain. I'm just big on fail safe operation I guess. Good to hear turning a stock bottom end that deep has worked out for you. </TD></TR></TABLE>
Just last night this happened to a guy I raced. He had a built LS/VTEC (rods, psitons, rod bolts, race bearings, slight overbore etc.) I think he missed 5th gear.
He said he didn't.
Old Jun 13, 2007 | 03:26 PM
iheartintegras's Avatar
What kinda power are you putting down Rodney? And what engine management?
Old Jun 13, 2007 | 03:45 PM
Rodney's Avatar
Default Re: (iheartintegras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iheartintegras &raquo;</TD></TR><TR><TD CLASS="quote">What kinda power are you putting down Rodney? And what engine management?</TD></TR></TABLE>
nothing special, 194whp, tuned conservative (ie rich) J's Racing tuned the car with a jdm p30.
IemSpooled219
Oct 25, 2011 01:55 PM
ricekiller1
Nov 27, 2007 11:25 PM
sinister6
Oct 3, 2005 05:42 PM
mtber
Jun 10, 2004 11:32 PM
Type-Rare#1248
Jun 10, 2002 10:57 PM
