(QUICK) Injector problem and question
Old Jun 12, 2007 | 10:48 AM
2slowGs-R's Avatar
Default (QUICK) Injector problem and question
Hey Honda-techers, I have a 94 Gs-r and one of my injectors tip cracked. The part that cracked and broke off is the plastic part that you insert into the manifold itself. I have an extra set of 94 Civic DX injectors laying around in my garage, i was wondering if you guys know if it will work on my car without any problems? and is it the same size as gsr injectors? I know that gsr are 240cc's but im really not sure about the dx injectors since i hear mix stories abouts its size. And also, using a civic fuel regulator on my gsr, will that also be okay with 36/38 psi not at WOT? Thanks a lot! -Ko
Old Jun 12, 2007 | 03:11 PM
2slowGs-R's Avatar
BUMP! I just tried putting the civic injectors into my integra and it ran so much smoother and better. I need to know from more experienced guys if it safe to drive like this? the injectors were from and obd1 civic so i assume itll be a straight plug and play to my 94 gsr. It my daily driver so i need to know the correct information. thanks guys! -Ko
jaap_15
11
Apr 30, 2013 02:20 PM
its WANG yoO
Jul 4, 2004 08:05 AM
dariusz
May 19, 2002 05:23 AM
