96-00 suspension on a 92?
Quick question I am looking at buying a suspension setup but it is off of a 99 civic but I have a 92. Will the suspension bolt right up or will I have issues? I have after market rear lower control arms. I thought that was the only differences in the years or are there other differences?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 »</TD></TR><TR><TD CLASS="quote">I heard someone has some progress he will let ya test with and see how you like them
I know I know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">the car needs a little more than suspension to make it go faster.</TD></TR></TABLE>
Don't you have a car to get running?
Seriously though does anyone know?
</TD></TR></TABLE>I know I know
the 92-95 rear lca are wider where the bolt goes thru the bottom of the shock assembly...96-00's have a skinny rear lca...so it's hard to use a rear shock from a 96-00 on a 92-95 (prolly not worth the modification needed)...but it's easier to use a 92-95 rear on a 96-00 (u can just add washers to fill the gap, cuz the 96-00 rear lca is skinnier...
make sense...to sum up my answer would be to find a setup from a dc2 teggy or another 92-95 civic...94-01 integra will bolt right up (except for type r)...u can get type r for your hatch, but u will also need to get type r rear lca's...
-drew
-drew
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dbang003 »</TD></TR><TR><TD CLASS="quote">the 92-95 rear lca are wider where the bolt goes thru the bottom of the shock assembly...96-00's have a skinny rear lca...so it's hard to use a rear shock from a 96-00 on a 92-95 (prolly not worth the modification needed)...but it's easier to use a 92-95 rear on a 96-00 (u can just add washers to fill the gap, cuz the 96-00 rear lca is skinnier...
-drew</TD></TR></TABLE>
Drew thanks for the info. I am running the d2 lower control arms and you can change out the bushings on those. So I think I can just order the bushings for the 96 and throw them on.
X2
96-00 civic rear lca too thin!
X2
