All 96-00 EK's on F2 Function & Form Suspensions pls POST PICS!
I finally got "real" full coilovers for my 96 ek 4 door,... "at the moment" on stock shocks and no-name garbage (ie. ractive or ebay type) coilover sleeve set up, just got F2's for it "not on the car yet" and from what i understand hieght adjustment needs to be set before bolting in lower control arms,... right now i have the units off the car sitting with spring pre-loaded hand tight and locked, and lower collars spun as far as they can come up, from what i've been told that is already at a "slammed" setting, and if i wanted more i'd have to put more pre-load on the spring, which i know is worst if i have the collar spun to its max already.
i know there is a few people on this site that are on them, if you dont mind posting pics, and what the coilovers are set up at.
pls and thank you.
Modified by CooL J RocK at 8:11 AM 6/12/2007
pls and thank you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooL J RocK »</TD></TR><TR><TD CLASS="quote">I finally got "real" full coilovers for my 96 ek 4 door,... on stock shocks and no-name coilover sleeve set up, just got F2's for it and from what i understand hieght adjust ment needs to be set before bolting in lower control arms,... right now i have the units off the car sitting with spring pre-loaded hand tight and locked, and lower collars spun as far as they can come up, from what i've been told that is already at a "slammed" setting, and if i wanted more i'd have to put more pre-load on the spring, which i know is worst if i have the collar spun to its max already.
pls and thank you.</TD></TR></TABLE>
for some reason i have trouble understanding this thread... i'm serious.
so u have f2s? or u have stock shocks and sleeves? if u already have f2s then why do u need pictures of other EKs on other coils? what is this bit about a "slammed" setting... ? i'm really confused
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooL J RocK »</TD></TR><TR><TD CLASS="quote">I finally got "real" full coilovers.</TD></TR></TABLE>
So your last set were "FAKE"...where they paper mache?
edited.... i hope the educated can understand that... sorry trying to make sense while trying to sell service to nissan customers
well u can adjust ur supsension while it's bolted onto your car. and all you need to do to get the lowest settings is turn the sleeves all the way down as far as they can go hehe
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman »</TD></TR><TR><TD CLASS="quote">If you want to "slam" the car. You need to lower the collar down into the lower body.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nathanong87 »</TD></TR><TR><TD CLASS="quote">well u can adjust ur supsension while it's bolted onto your car. and all you need to do to get the lowest settings is turn the sleeves all the way down as far as they can go hehe</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CooL J RocK »</TD></TR><TR><TD CLASS="quote">right now i have the units off the car sitting with spring pre-loaded hand tight and locked, and lower collars spun as far as they can come up, Modified by CooL J RocK at 8:11 AM 6/12/2007</TD></TR></TABLE>
pics, not a plug, just pics
Mind you known of these cars are "slammed" as far as i know, they all have more room to go using the lower mounts, as we do not reccomend slammage for anything other than hard-parking
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pworld »</TD></TR><TR><TD CLASS="quote">
Mind you known of these cars are "slammed" as far as i know, they all have more room to go using the lower mounts, as we do not reccomend slammage for anything other than hard-parking </TD></TR></TABLE>
people would probably disagree with you in the slammed thread
Those are some sick cars though,wow.
they all have more room to go using the lower mounts </TD></TR></TABLE>
lower mounts as in the bottom ring...?see your saying their sitting at a decent height, but still have alot more teeth left? or atleast a significant amount.
would you happen to have any pics of them just all th way down to its lowest setting?
just curious
either way f2's
just curious
either way f2's
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JamesL »</TD></TR><TR><TD CLASS="quote">Why wouldn't you be able to adjust them on the car?</TD></TR></TABLE>
the proper way to adjust ride height on these full coils is to just snug the spring between the collars and do all your height adjustments by spinning the bottom shock mount, which changes the length of the shock entirely. not the spring. this requires taking the off suspension fork (front) or disconnecting from the LCA (rear).
you run into problems if you start trying to just tighten of loosen the collar and tightening or loosening hte spring. can you do it? yes. will it lower your car? yes. will it ride like ****? you bet.
Nichelson_Performance
Suspension & Brakes
12
Jan 18, 2010 01:32 PM
ZXVIIR
Suspension & Brakes
Jun 12, 2007 02:23 PM
