Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Third Gear sticking????
Old Jun 12, 2007 | 12:01 AM
Kentagious's Avatar
Default Third Gear sticking????
So I have an '07 Si with alittle over 2000 miles on it, and for some reason every once in awhile(usually when the car is cold) third gear won't go in all the way and it'll grind on me. It's only usually when its cold, or at some other random time. It doesn't to it with I shift a high RPMs however...not that I have problem with shifting at high RMS , its just not very economical around town. I'm wondering if the syncro might be going out, or I've heard that Honda has a new tranny fluid out and maybe I need to have mine changed...any help would be apriciated
Thanks
Old Jun 12, 2007 | 12:40 AM
Aco512's Avatar
your not the only one
its a common problem with the dc5/si's (6-speeds)
we call it an "invisible wall"
the best thing you can do is upgrade your tranny fluid
i hear royal purple makes a huge difference
i still have yet to try it
Old Jun 12, 2007 | 08:31 AM
FG2 chilotz's Avatar
Default Re: Third Gear sticking???? (Kentagious)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kentagious &raquo;</TD></TR><TR><TD CLASS="quote">So I have an '07 Si with alittle over 2000 miles on it, and for some reason every once in awhile(usually when the car is cold) third gear won't go in all the way and it'll grind on me. It's only usually when its cold, or at some other random time. It doesn't to it with I shift a high RPMs however...not that I have problem with shifting at high RMS , its just not very economical around town. I'm wondering if the syncro might be going out, or I've heard that Honda has a new tranny fluid out and maybe I need to have mine changed...any help would be apriciated
Thanks </TD></TR></TABLE>
07 Si owner and yes I too have that invisible wall others talk about and plan on harrasing the stealership into changing out the tranny fluid! I suggest you use the warranty that your car was bought with and get it handled
Old Jun 12, 2007 | 08:37 AM
TRE_'s Avatar
Not to be a dick but SEARCH.... this topic has been covered more than enough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Search Function FTW &raquo;</TD></TR><TR><TD CLASS="quote">
» Search Results
Your search for '3rd gear' returned 7 results.- (IN the '06 Civic forum)</TD></TR></TABLE>
Try other keywords like grind, gear, third, 3rd, shifting, etc.
I would try to get the trans fluid swapped out soon -- pref. for free by the dealership or check out my DIY in the sticky.
Old Jun 12, 2007 | 08:43 AM
Default Re: (TRE_)
We know and thanks for the search reminder but he was looking to see if the problem exsisted in the 07 Si and so I guess we solved that right ?
Old Jun 12, 2007 | 03:12 PM
anavrin351's Avatar
Default Re: (FG2 chilotz)
the 07 question has been covered in more than one of those other threads
Old Jun 12, 2007 | 03:40 PM
TRE_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FG2 chilotz &raquo;</TD></TR><TR><TD CLASS="quote">We know and thanks for the search reminder but he was looking to see if the problem exsisted in the 07 Si and so I guess we solved that right ? </TD></TR></TABLE>
What is the point of your post?
Old Jun 12, 2007 | 04:36 PM
Aco512's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FG2 chilotz &raquo;</TD></TR><TR><TD CLASS="quote">We know and thanks for the search reminder but he was looking to see if the problem exsisted in the 07 Si and so I guess we solved that right ? </TD></TR></TABLE>lol, just to let you know that this same problem has been on from the 02 type-s all the way to the 07 si
common problem in most 6 speed transmissions
Old Jun 13, 2007 | 11:42 PM
Kentagious's Avatar
Default Re: (Aco512)
Cool, thanks for the feedback!!! I'll get it checked out.
Old Jun 13, 2007 | 11:57 PM
2f2fc1v1c's Avatar
Default Re: (Kentagious)
use diff... oil
mk818
Aug 27, 2012 08:37 AM
infamouskillas
May 17, 2008 09:56 PM
humboldt_skim
10
May 16, 2008 10:56 AM
oryanh
Jun 2, 2002 01:08 PM
Nighthawk GS-R
Mar 13, 2002 06:15 AM
