HID bulb with high beams?
Old Jun 11, 2007 | 10:49 PM
bl1tzk1213g's Avatar
Default HID bulb with high beams?
Currently I have Pilot HID conversion kit for my civic (h4)
I am in need of high beam which I dont have. Is it possible just to buy a bulb with high beam or I need a whole new HID kit with high beam?
Old Jun 11, 2007 | 11:02 PM
Rayz_Si's Avatar
From: Land of the Hillbillies and Shotguns, Ontario, Canada
Default Re: HID bulb with high beams? (bl1tzk1213g)
You can actually buy the hi/lo beam bulb on Ebay and keep your HID system.
Old Jun 12, 2007 | 05:52 PM
Default Re: HID bulb with high beams? (Rayz_Si)
oh thanks. BTW can I get different a different temeprature or is determined by my kit? I currently have 6000K, can i use 8000K?
Old Jun 22, 2007 | 12:22 PM
menappi's Avatar
It's called H4 Bi-Xenon - pretty sure that's what the pilot's use. If you find a place that just sells the bulbs and wiring harness I'd go for those - you can use your other ballasts and save a little cash.
Modified by menappi at 1:21 AM 6/26/2007
Old Jun 22, 2007 | 12:31 PM
Genuine Rolla's Avatar
you can buy another bulb from ebay. I'd get 4300K if I were you.
Old Jun 22, 2007 | 01:15 PM
OC Geezer's Avatar
There is no point in putting HID's in your hi beams.
First of all, the way hi beams work, would screw up your HID's after a short time because unlike the lo's it just ignites and there is no chance for the HID's to actual warm up to optimal temperature.
Secondly, it's a waste of money because how often do you use your hi beams?
Just my .02
FunkyFresh_EK
Lighting
Sep 22, 2011 08:06 AM
OTiS515
Lighting
May 12, 2009 09:17 AM
vtek9
Lighting
Sep 8, 2007 08:32 AM
Mr.DC2TurBo
Mar 9, 2003 02:24 PM
goldffronts
18
Feb 14, 2003 08:47 PM
