wtf is wrong with my car
Old Jun 11, 2007 | 09:50 PM
EF Driver's Avatar
Default wtf is wrong with my car
ok so this mornin i tried to start my car and i heard a loup popping noise so when i took out the spark plugs i saw like a lil white smoke coming out and when i cranked it without the spark plugs in it i see gas liquid flyin out the number 3 cylinder. is this all normal??
Old Jun 11, 2007 | 09:56 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: wtf is wrong with my car (EF Driver)
white smoke is generally coolant.. so you might have popped a head gasket. how much liquid did you see fly out?
you should probably do a compression test to determine if you did break a headgasket. the liquid thing is weird, but you might have broken the gasket enough to allow the cylinder or cylinders to fill with coolant, which would then cause your engine to hydrolock, which is a bad thing.
you can also drain the oil, and if it looks like a milkshake instead of oil,or if there is coolant in it, you need to change your head gasket for sure.
Old Jun 11, 2007 | 10:00 PM
sexyrex's Avatar
yea you nailed it sanimalp for sure a headgasket or head...
503_EF9's Avatar
Default Re: wtf is wrong with my car (sanimalp)
check the exhaust.
white smoke is bad head gasket.
put a towl in the cylinder hole crank the engine and let it blow out if it doesnt compression problems.
and the milky oil previoulsy stated also.
Old Jun 12, 2007 | 12:16 AM
EF Driver's Avatar
ya when the liquid flew out and hit the towel it smelled like gas and the lil smoke was comin out of the manifold also it wasnt a dark white smoke just like a light one dat u can barely see unless u look up close
benjamin
Jul 2, 2022 11:49 AM
a3k
Jul 26, 2009 10:36 PM
gray_civic_coupe
Jan 16, 2006 03:15 AM
bey
Jul 14, 2004 07:05 AM
