POPING NOISE!!!
Old Jun 11, 2007 | 05:32 PM
haroldthefly91crx's Avatar
Default POPING NOISE!!!
1990 crx si,
when i shift and slow down there i a poping sound, a loud one
it sounds expensive nd im hoping to get some imput as to waht it is
Old Jun 11, 2007 | 05:35 PM
Jasond's Avatar
Default Re: POPING NOISE!!! (haroldthefly91crx)
It sounds to me like you are running really rich and that popping noise you are hearing is excess fuel being detonated in the exhaust system. However, lets get a second opinion.
Old Jun 11, 2007 | 05:39 PM
Default Re: POPING NOISE!!! (Jasond)
it doesnt sound like a backfire, it sounds like metal hitting metal
Old Jun 11, 2007 | 05:42 PM
Mr. Giggles's Avatar
Sound Clip would help
Old Jun 11, 2007 | 06:06 PM
Default Re: POPING NOISE!!! (SmrCRX)
i have no idea how to do that
Old Jun 11, 2007 | 06:13 PM
sexyrex's Avatar
where's the noise coming from? or do you even know? and this happens when decelerating correct?
Old Jun 11, 2007 | 06:22 PM
Default Re: POPING NOISE!!! (sexyrex)
its comming from the engie compartment, ad i can feel it as well and yes it it happens while decerating and while shifting
Old Jun 11, 2007 | 06:25 PM
ef-hatchcrap's Avatar
Sounds like a loose mount or some thing
Check all your mounts and suspension belts
Old Jun 11, 2007 | 06:28 PM
Default Re: POPING NOISE!!! (ef-hatchcrap)
thats whats im hoping
Old Jun 11, 2007 | 06:38 PM
sexyrex's Avatar
can you duplicate the noise with the car parked?
Old Jun 11, 2007 | 06:41 PM
no, only when i let the clutch out and give it gas so it jumps
Old Jun 11, 2007 | 06:47 PM
sexyrex's Avatar
you know what you could do....set the parking brake, chock the wheels and load up the engine. do it right now....gogogoog, and you need a helper also, dont stand in front of the car. what the engine movement and listen for noise. inspect engine mounts
Old Jun 11, 2007 | 06:49 PM
4g hatch's Avatar
sounds like a mount is shot or maybe you have a bad bushing in the suspension
Old Jun 11, 2007 | 06:55 PM
Default Re: (4g hatch)
i checked out the mount and i knly found one that looks kinda shot but not enough to make a sound like that but i could see it bring a bushing, ill have to check that out when its light out and not raining
Old Jun 11, 2007 | 06:59 PM
sexyrex's Avatar
sit inside the car than and load the engine. spike the gas pedal. if the noise persists than its most likely a motor mount. are you sure its not a clunk? and not a pop?
Old Jun 11, 2007 | 07:17 PM
Default Re: (sexyrex)
honestly it could be a clunk or a pop, but i cant get it to happen while im not moving, only when im in motion
Old Jun 11, 2007 | 07:25 PM
sexyrex's Avatar
Default Re: (haroldthefly91crx)
well the point of this test is to get your engine to jerk in which ever direction to see how much engine movement there is. all that excessive engine movement leads to bad mount(s) causing clunks...
Old Jun 11, 2007 | 07:33 PM
4g hatch's Avatar
while doing the test have somebody see if the motor is moving more than it should. is it coming from one side of the car or just under the hood
Old Jun 11, 2007 | 08:07 PM
julioboostamante's Avatar
i hope its not your loose tranny mounts. I had a rear tranny mount get loose and crack the tranny housing and it did just that. It popped till it broke and i think i could have saved myself a headache if i just made sure to torque my bolts properly.
Old Jun 11, 2007 | 09:37 PM
89s1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef-hatchcrap &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like a loose mount or some thing
Check all your mounts and suspension belts</TD></TR></TABLE>
if it is just as the clutch comes out then it could be the rear mount...
Old Jun 11, 2007 | 10:02 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: POPING NOISE!!! (89s1)
serious bearing failure in the transmission will also cause clunking. if the input shaft bearing fails, you get all kinds of strange noises.
check your mounts first. if none of them are bad.. then it *may* be trans rebuild time.
Old Jun 12, 2007 | 03:53 AM
SnakeBait's Avatar
Default Re: POPING NOISE!!! (sanimalp)
axles?
Old Jun 12, 2007 | 06:28 AM
Default Re: POPING NOISE!!! (SnakeBait)
axels are good, and i am starting to think it may be something internal but i hope not
crx1racing
May 25, 2005 05:43 PM
ibanezrgking
May 19, 2002 08:29 PM
jujubee
Apr 21, 2002 07:06 AM
