jdm eg6 steering wheel into srs car?
Old Jun 11, 2007 | 04:39 PM
redface's Avatar
Default jdm eg6 steering wheel into srs car?
probably an easy answer but im so used from from puttin this car back to gutted that i'm jus overlooking it. im puttin my eg hatch with srs back together but im puttin the jdm eg steering wheel in it. you have to take the srs unit off the hub to make the feel fit but how do you get the horn to work. inside the jdm wheel all there is is one power wire. in the u.s wheel there's hots and grounds which run to a connector that in turn the wire from the dash plugs into also to power it but this wire is on the srs stuff so can't go back into the wheel. in turn can anyone help me out to get the horn to work in my car?? thanks
Old Jun 11, 2007 | 04:41 PM
Eran's Avatar
HT White Ops
Default Re: jdm eg6 steering wheel into srs car? (redface)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redface &raquo;</TD></TR><TR><TD CLASS="quote">probably an easy answer but im so used from from puttin this car back to gutted that i'm jus overlooking it. im puttin my eg hatch with srs back together but im puttin the jdm eg steering wheel in it. you have to take the srs unit off the hub to make the feel fit but how do you get the horn to work. inside the jdm wheel all there is is one power wire. in the u.s wheel there's hots and grounds which run to a connector that in turn the wire from the dash plugs into also to power it but this wire is on the srs stuff so can't go back into the wheel. in turn can anyone help me out to get the horn to work in my car?? thanks</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=1760922
Old Jun 11, 2007 | 05:05 PM
dnt94civic's Avatar
https://honda-tech.com/zerothread?id=273474
Old Jun 11, 2007 | 06:40 PM
redface's Avatar
Default Re: jdm eg6 steering wheel into srs car? (dnt94civic)
thanks alot....definately wouldn't have figured that one on my own.
beefjerky
Nov 4, 2005 07:28 PM
D-series ninja
Apr 29, 2005 03:50 PM
bankhead83
Apr 8, 2004 02:35 PM
