CEL code P1336
CEL came on yesterday while i was driving..went to autozone this morning to have them pull the code. it said P1336.. they told me to go to the dealer to ask them wat it was, bc their books only went up to 1000. dealer tried charging me 87 bucks just to tell me what it meant.
does any1 know what this code means?? car is running fine and i havnt noticed a difference since CEL came on...
https://honda-tech.com/zerothread?id=466877
P1336 Engine Speed (RPM) Fluctuation Sensor Intermittent Interruption
» Search Results
Your search for obd2 codes returned 36 results
» Search Results
» Search Results
Your search for crank fluctuation sensor returned 33 results.
__________________________
It's mounted on the oil pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek360 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=979961</TD></TR></TABLE>
yay!
Someone was direct enough!
yay!
has the timing belt been done recently ? i have seen many times guys dont put the harness back into the front cover and the alt belt cuts the wire's. look near the belt and see if the sheilding and wires are cut.
Draggin99Si
Aug 18, 2003 08:36 AM
Civic2Fast
Feb 11, 2003 07:19 PM
