ELD??? CODE!!!!
Old Jun 11, 2007 | 03:12 PM
Leviata-N's Avatar
Default ELD??? CODE!!!!
Hey another question, why the ELD is activated????
Old Jun 11, 2007 | 05:52 PM
Crx Jimmy's Avatar
Default Re: ELD??? CODE!!!! (Leviata-N)
ELD stands for electronic load detection. it had something to do with altering your idle when you have more electrical accessories on. I believe if that code comes up you need a new under hood fuse box as it is built into it and not replaceable. If you are doing a b series swap, eld is not used and the wire needs to be cut for it on the ecu and something else wired in there.
Old Jun 27, 2007 | 03:56 PM
Leviata-N's Avatar
Default Re: ELD??? CODE!!!! (Crx Jimmy)
Thank you Jimmy....
Old Jun 27, 2007 | 04:10 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">If you are doing a b series swap, eld is not used and the wire needs to be cut for it on the ecu and something else wired in there.</TD></TR></TABLE>
Yep, #B19 @ the ECU and it becomes the Knock sensor.
Old Jul 3, 2007 | 11:31 AM
Leviata-N's Avatar
Default Re: ELD??? CODE!!!! (VtecSyndrome)
Man you help me A LOT thank you so much!!!!
jonathan13
Jun 24, 2009 08:39 AM
jonathan13
Apr 20, 2009 06:21 AM
xkagax
Jan 12, 2006 09:29 PM
zccr-xsi
Sep 11, 2005 07:51 AM
slowpokesi
Apr 7, 2003 12:19 AM
