Ek coilovers on Dc?
They will fit, but the metal bushing on the control arm would have to be shaved down in order to fit. I was able to grind it down to fit with the stock dc control arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typet »</TD></TR><TR><TD CLASS="quote">They will fit, but the metal bushing on the control arm would have to be shaved down in order to fit. I was able to grind it down to fit with the stock dc control arm.</TD></TR></TABLE>
Are the control arms themselves not swappable? Or is there a difference in alignment? Seems like a better, easier way than customizing.
ek controls are shorter then dc control arms
i think he means where the coilover goes over the control at the bottom is a little thicker on ek control then dc control arms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">ek controls are shorter then dc control arms
i think he means where the coilover goes over the control at the bottom is a little thicker on ek control then dc control arms</TD></TR></TABLE>
other way around. EK control arms are WAY longer than DC/EG control arms. and please don't tell me you're putting improper shocks on your ITR
yeah you would have to shave the bushing at the LCA, but if you have a hype R why not spend the money to get application specific parts. just my $.02
iv got a set of $1900 Tein Ra's, with 14k,12k springs rates on my ek right now, and i want them on my itr where i can put them to good use, and if all it means is switching out the lca's then thats what im goin to do, i need to get new lcas on the R anyway, i spun the heads off the bolts on the lcas where the shock goes through and need new lcas, so this is goin to work out perfect
4drgsr96
Oct 24, 2006 07:20 AM
