Ek coilovers on Dc?
Re: Ek coilovers on Dc? (01-0720)
They will fit, but the metal bushing on the control arm would have to be shaved down in order to fit. I was able to grind it down to fit with the stock dc control arm.
Re: Ek coilovers on Dc? (typet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typet »</TD></TR><TR><TD CLASS="quote">They will fit, but the metal bushing on the control arm would have to be shaved down in order to fit. I was able to grind it down to fit with the stock dc control arm.</TD></TR></TABLE>
Are the control arms themselves not swappable? Or is there a difference in alignment? Seems like a better, easier way than customizing.
Re: Ek coilovers on Dc? (94si94cx)
ek controls are shorter then dc control arms
i think he means where the coilover goes over the control at the bottom is a little thicker on ek control then dc control arms
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01-0720 »</TD></TR><TR><TD CLASS="quote">ek controls are shorter then dc control arms
i think he means where the coilover goes over the control at the bottom is a little thicker on ek control then dc control arms</TD></TR></TABLE>
other way around. EK control arms are WAY longer than DC/EG control arms. and please don't tell me you're putting improper shocks on your ITR
yeah you would have to shave the bushing at the LCA, but if you have a hype R why not spend the money to get application specific parts. just my $.02
Re: Ek coilovers on Dc? (electron_si)
iv got a set of $1900 Tein Ra's, with 14k,12k springs rates on my ek right now, and i want them on my itr where i can put them to good use, and if all it means is switching out the lca's then thats what im goin to do, i need to get new lcas on the R anyway, i spun the heads off the bolts on the lcas where the shock goes through and need new lcas, so this is goin to work out perfect
4drgsr96
10-24-2006 07:20 AM
