Suspension & Brakes Theory, alignment, spring rates....
Need help. Brake problem.
Old Jun 11, 2007 | 12:31 PM
HRD's Avatar
HRD
Default Need help. Brake problem.
Alright this started happening not too long ago and simply just out of the blue. When I push on the brakes over 30mph my wheels start to shake, making the whole car and steering wheel shake. Everything is stock up front w/ eibach pro springs. Is this a common problem that just requires replacement of basic brake components? Any ideas?
Old Jun 11, 2007 | 04:30 PM
HRD's Avatar
HRD
Or could it just be an alignment type problem?
Old Jun 11, 2007 | 04:32 PM
excivicboy96's Avatar
Default Re: (Alex Trebek)
can you feel pulsations in the pedal?
Old Jun 11, 2007 | 11:24 PM
HRD's Avatar
HRD
Yes I can, but very light. I'm sure the pulsations are caused by the front wheels shaking and the brakes being applied. The car and steering wheel shake a whole lot more than the petal pulsates.
Old Jun 12, 2007 | 10:21 AM
HRD's Avatar
HRD
bump
Old Jun 12, 2007 | 10:40 PM
HRD's Avatar
HRD
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex Trebek &raquo;</TD></TR><TR><TD CLASS="quote">bump </TD></TR></TABLE>
Old Jun 13, 2007 | 06:04 AM
preludetospeed's Avatar
I would say that your problems would be brake rotors. Mine is doing the same thing. You might be able to make it a little better if you take if up to 50- 60 and brake hard to heat up the brakes (DO NOT STOP ALL THE WAY) and repeat then drive around and let them cool. Sometimes this will help by removing the brake material that has built up on the rotors.
Old Jun 13, 2007 | 06:25 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: (preludetospeed)
It could be warped rotors OR unevenly worn pads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludetospeed &raquo;</TD></TR><TR><TD CLASS="quote"> Sometimes this will help by removing the brake material that has built up on the rotors. </TD></TR></TABLE>
Any buildup should be removed with brake cleaner, not driving like a dumbass.
Old Jun 13, 2007 | 08:49 AM
Well that’s what I do at the shop that i work at and no one class me a dumb *** when it comes back and it inst shaking anymore. And brake cleaner wont take off anything but dust and grease
Modified by preludetospeed at 12:00 PM 6/13/2007
Old Jun 13, 2007 | 10:47 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludetospeed &raquo;</TD></TR><TR><TD CLASS="quote"> And brake cleaner wont take off anything but dust and grease </TD></TR></TABLE>
Well what the hell else builds up on there?
Old Jun 13, 2007 | 11:01 AM
Brake material from the brake pads
Old Jun 13, 2007 | 11:02 AM
Tyson's Avatar
Default Re: Need help. Brake problem. (Alex Trebek)
you probably have warped rotors and you need to just resurface or buy new rotors.
HOWEVER, the warped rotors arent making your whole car shake. your balljoints and or tie rods and or steering rack bushings are shot and need replacement.
warped rotors on a sound chassis just makes a mild pulsating. a worn suspension will amplify the pulsating into the violent shaking youre describing.
if you just change your rotors now ignore everything else, then youll likely have to deal with them again soon as the play helps cause the rotors to warp. its a chicken and egg situation.
Old Jun 13, 2007 | 01:52 PM
HRD's Avatar
HRD
I don't know much about suspension but is there an easy way to identify which one of those things could be the problem, on top of the warped rotors? Or should I just go out and replace all of them?
Thanks for the response.
Old Jun 13, 2007 | 02:03 PM
Tyson's Avatar
you just have to jack up the car and start shaking things. isolate the source of hte play with your hands. having a friend helps.
Old Jun 13, 2007 | 03:10 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludetospeed &raquo;</TD></TR><TR><TD CLASS="quote">Brake material from the brake pads</TD></TR></TABLE>
We call that brake dust. "brake material" Shouldn't build up on the surface of the rotor as the pad itseld will wipe anything off the surface that's not a lubricant. And brake pad material is NOT a lubricant in any way, shape, or form.
Old Jun 15, 2007 | 05:11 AM
I never said anything about it being a lubricant and if the brakes are hot then there is no reason that it wouldn't get on the rotor and stay. but that’s because I know it works but ohh well you dont have to believe me
Modified by preludetospeed at 9:21 AM 6/15/2007
choua01
Honda Civic (2006 - 2015)
Jun 20, 2012 11:43 AM
jag123
Dec 28, 2010 07:54 PM
Flite
Dec 7, 2006 07:59 AM
invboost
Nov 4, 2003 10:00 AM
charjacq
Jun 20, 2002 10:32 AM
