Acid rain & clear coat etching...
On my trunk and wing I have some light etching in my clear coat..my buddy across the st has the same thing on his hood on his truck. Both newer vehicles w/solid paint.
You can't feel it w/your finger..but can see it under direct sunlight and fluorescent light.
I was told to try distilled vinager but that didn't help @ all.
Any thoughts..what do I need to do...?
Thanks.
Thanks.
You may want to read through this thread and see if it looks/sounds like what is happening to yours.
https://honda-tech.com/zerothread/2003472
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -NA-aLL-thE-wAy- »</TD></TR><TR><TD CLASS="quote">You may want to read through this thread and see if it looks/sounds like what is happening to yours.
https://honda-tech.com/zerothread/2003472</TD></TR></TABLE>
Thanks, but it's a little different..
Picture someone washing their car..and not drying it..then waxing over top of water spots...
Thats what it looks like..however no amount of rubbing gets them off...best I can tell it's almost etched into the clear...
https://honda-tech.com/zerothread/2003472</TD></TR></TABLE>Thanks, but it's a little different..
Is it all over the place? Sounds like the same thing that bird crap does to a clear coat. If it's acid rain try wetsanding it with 2000 then buffing it. I did that on a 06 Subaru Forester and it came out. Can't hurt to try, but if that doesn't work you may need to refinish...but that'll be expensive.
Hit it with some rubbing compound and then wax. I'd recommend 3m and any sort of Meguiar's carnauba for the compound/ wax.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Leo C. »</TD></TR><TR><TD CLASS="quote">Hit it with some rubbing compound and then wax. I'd recommend 3m and any sort of Meguiar's carnauba for the compound/ wax.</TD></TR></TABLE>
I've even used a Porter Cable w/no luck.
I've got pictures, just need to get them online.
eyeyeyeyeyey. We had a dumbass come into our work with this problem. The detail shop (the guy is a tool) down at a dealership washed a car, and they use some crazy cleaner with acid. He didn't wash the car fully and when it dried it basically burned "water marks" into the clear. You cant see it straight on, only at a angle and its real faint. Exactly like a watermark but it wont come out. Your going to have to sand and buff the **** out of that clear to get it out. We tried everything, clay bar, all the polish/wax we had in the shop, sanding with 1500 wet then 3000 wet and buffing the **** out of it. Nothing really worked. Yours might not be as bad, but I think he let it set too much and prettymuch needs a overall to get rid.
I took a pic of my wing and circled the "problem areas" so you all can see what I am talking about..
On my trunk and wing..
Any help would be fantastico !!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alexander »</TD></TR><TR><TD CLASS="quote">Try a claybar.</TD></TR></TABLE>
Been there done that...
Question: When you used a PC on the paint what product did you use to polish?
If it was aggressive enough, it probably cannot be done without the use of a rotary buffer with the appropriate pad and compound/polish.
If that doesn't cut it, then wetsanding or feathersanding would be tried.
This may be removed, but if it's STILL visible, there's not much you can do but I can bet it will look better than when you started.
I've seen a Viper with a bird dropping etching that was so deep it could not be completely removed, even by my Meguiar's instructor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brad. »</TD></TR><TR><TD CLASS="quote">Question: When you used a PC on the paint what product did you use to polish?
I've seen a Viper with a bird dropping etching that was so deep it could not be completely removed, even by my Meguiar's instructor.</TD></TR></TABLE>
All I had @ the time was some Meguirs Scratch X and some Turtle Wax Polish Compound...neither worked...
I have on order a 3 stage polish from autogeek.net. I use my orange cutting pad on my PC.
When it gets here, I will let everyone know how it does..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok »</TD></TR><TR><TD CLASS="quote">if it is acid rain spots, it may have to be wetsanded out if compounding doesnt help.
vinegar only works on mineral deposit water spots</TD></TR></TABLE>
Well, I talked to my local detailer of 25 yrs...and he gave me a bottle of the stuff he uses...
IT did get the water spots out...but the dimples in the clear are still there..defintly a wet sand canidate..
Any ideas/comments on how to attempt that safely?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK »</TD></TR><TR><TD CLASS="quote">Got a name of the stuff he gave you?</TD></TR></TABLE>
Negative.
It's a light blue looking color...lol..
I ordered some polish's from autogeek.net. Where I get all my stuff.
Poorboys SSR 3.0
Poorboys SSR 2.5
Poorboys SSR 1.0
See if that helps...if not..it's wetsand time..
Negative.
Poorboys SSR 3.0
Poorboys SSR 2.5
Poorboys SSR 1.0
Hey guys this is what's happening to my car. Any idea how to fix?
This is how my car is. It's happening on the rear quater panel at the top of the passenger front door.
Modified by oddmut at 6:23 PM 7/9/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec »</TD></TR><TR><TD CLASS="quote">
Negative.
Poorboys SSR 3.0
Poorboys SSR 2.5
Poorboys SSR 1.0
After an hr of polishing and glazing and sealing and waxing..lol..
I got 80% of it out. The water spots and halo's are gone, but the dimples in the clear are still there..sooo...I figure this winter I will wetsand the imperfections to bring it back...
Negative.
Poorboys SSR 3.0
Poorboys SSR 2.5
Poorboys SSR 1.0
</TD></TR></TABLE>After an hr of polishing and glazing and sealing and waxing..lol..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExVtec »</TD></TR><TR><TD CLASS="quote">Clear is peeling away...only way is to strip the clear and respray.
How do I go about stripping and are there clear coat spray cans I can use on my car? What brands do you recommend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oddmut »</TD></TR><TR><TD CLASS="quote">
How do I go about stripping and are there clear coat spray cans I can use on my car? What brands do you recommend?</TD></TR></TABLE>
no he means you need a full repaint to fix that problem. Or you can wetsand the whole car down and have to deal with it being single stage with no clear...
