bROKEn clutch pedal bracket (holder)...******I NEED HELP ASAP!!!********
the bracket that holds the Clutch pedal is broken, in order to fix this do i have to take out the dash, or can i just remove it while the dash is still in...
please help me any input will be acknowledged!
You can replace the clutch pedal bracket with the dash on. I have done this twice. You have to first get the vent tubes out of the way. They can be a pain. Make sure that you have a lot of time to do this. I did almost all of this inverted on my drivers seat. It is a pain and gets very frustrating since your arms dont bend certain ways and there is minimal lighting.
The most common reason these brackets break is either a bad or "sticky" clutch cable or an uber clutch that takes a lot of pressure to depress. I had a bad clutch cable and had to replace this bracket twice.
i_VTEC
66
May 21, 2013 10:45 AM
[626]95-GSR
11
Mar 29, 2003 09:13 PM
[626]95-GSR
Mar 27, 2003 10:49 PM
