swapping tranny
Ok so I blew the tranny in my 97 cx civic This is just my daily driver so I need to know if dx,ex civic tranny will be a direct swap 92-2000? an If the clutch set is the same too. This was going to be just a clutch job but turns out the tranny is shot
p.s. I did search
p.s. I did search
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uneek360 »</TD></TR><TR><TD CLASS="quote">ummmm, u searched and couldn't find the answer ?? Yes any D-series tranny will bolt right in...</TD></TR></TABLE>
that is what i said last time to another guy that posted the same question, i got yelled at, and no not all d-series will fit...only 92-00 d series will, anything before and after will not...so you are wrong...but yea, i'd suggest getting an ex tranny for your car...ehehhe...gl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">
that is what i said last time to another guy that posted the same question, i got yelled at, and no not all d-series will fit...only 92-00 d series will, anything before and after will not...so you are wrong...but yea, i'd suggest getting an ex tranny for your car...ehehhe...gl</TD></TR></TABLE>
lol... but y would i install a tranny from 1990 on a let's say 95 motor ?? Common sense tells me to use a tranny about the same yr or newer than the motor i have....
Any d-series hydro tranny will fit.
any 92-00 d-series clutch.
An ex tranny would be a killer upgrade for your cx if you are planning on modifying it later on.
Well, if you want a dx/cx tranny will be fine. The dx tranny has a little bit shorter gears, and still has that hella long 5th that the cx has. So for your daily you'll still get good mpg.
But whatever floats your boat holmes.
lol... but y would i install a tranny from 1990 on a let's say 95 motor ?? Common sense tells me to use a tranny about the same yr or newer than the motor i have....</TD></TR></TABLE>
unless you are installing it in an old school civic...but he is putting it on his eg...so yea, just clearing things up...hydro for 92-00, cable for 91-below...ya know what i'm saying? common sense ofcourse....gl again
Benjithx
Sep 26, 2007 08:56 PM
