gsr gears into ys1
Old Jun 10, 2007 | 11:49 PM
turbod da's Avatar
Default gsr gears into ys1
I have a 92gsr trans ,what I'd like to know if
I could put the gears out of a 94up gsr into the ys1
I gave the search button a work out but still came empty handed.
I read that 92gsr(cable)trans and 94upgsr are the same
but when I saw the gear ratio they are different...anyone have information
let me know..
Old Jun 11, 2007 | 05:53 AM
WWDTrackRacer's Avatar
New User
Default Re: gsr gears into ys1 (92gs)
the gears can interchange. the ratios are not identical. you need to read the stickies up top.
Old Jun 11, 2007 | 07:56 AM
SwappedTURBOegg's Avatar
http://www.outlawatvclub.com/u....html
Old Jun 12, 2007 | 12:26 AM
turbod da's Avatar
So if I was to get a lsd for the ys1
would it work if I change the internals to gsr (94upgsr trans)
or do I get a 94 up gsr lsd?
Modified by 92gs at 2:23 AM 6/12/2007
Old Jun 12, 2007 | 03:24 AM
HondaCivicSiR1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92gs &raquo;</TD></TR><TR><TD CLASS="quote">So if I was to get a lsd for the ys1
Modified by 92gs at 2:23 AM 6/12/2007</TD></TR></TABLE>i have a hydro b16a gear set in my ls ys1 case stock diff .if you use a hydro gear set you need to use only hydro parts and for the diff you need a gsr/itr diff with the ring gear.i hope that helps
killerpenguin21
Apr 11, 2007 08:04 PM
Death_to_Thieves
Mar 11, 2004 09:08 PM
