Honda S2000 Honda S2000
FINAL GEAR ?????
Old Jun 10, 2007 | 10:51 PM
ek_s2k's Avatar
Default FINAL GEAR ?????
whats the stock final gear on ap1 and would it be bad on the motor if upgrading it to 4.7? and how much power will it give.thnks
Old Jun 10, 2007 | 10:59 PM
ITRbroham's Avatar
shit post warrior
Default Re: FINAL GEAR ????? (ek_s2k)
AP1/2 OEM FD is 4.1.
4.7 FD isn't bad for the motor but it will affect top speed while improving acceleration. It will not improve the engine's power number-wise.
Old Jun 11, 2007 | 01:21 AM
ley's Avatar
ley
With 4.77's you will be cruising in Vtec on the highway.
Practicality is almost thrown out of the window.
Old Jun 11, 2007 | 05:29 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
4.56 is most likely your best bet... its doesnt sacrifice too much top speed, but at the same time will improve acceleration...
Old Jun 11, 2007 | 06:44 AM
wrayzor's Avatar
with 4.56's where do the rpm's sit cruising around 70 mph?
Old Jun 11, 2007 | 07:30 AM
wifesaynogo's Avatar
Default Re: (wrayzor)
whoever said you will be cruising in vtec doesnt know wtf there talking about...even at 75-80 in an ap1 you will be below 6000rpms...practicality is relative...it will be easier for the engine to push/pull the car when accelerating therefore increasing mpg theoretically...mpg is not dependent solely on rpm but also throttle position...thus if u need less throttle to sustain a given speed less fuel consumption...geez
Old Jun 11, 2007 | 07:48 AM
Nishant's Avatar
Default Re: (ley)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ley &raquo;</TD></TR><TR><TD CLASS="quote">With 4.77's you will be cruising in Vtec on the highway.
Practicality is almost thrown out of the window.</TD></TR></TABLE>
no you won't...vtec kicks in at 95mph in 6th. I had 4.77's on my Ap1
Old Jun 11, 2007 | 07:53 AM
papa5murf's Avatar
Default Re: (ley)
Guess you've never driven a car with 4.77's.
Old Jun 11, 2007 | 10:08 AM
S2KILLA's Avatar
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">
Guess you've never driven a car with 4.77's.</TD></TR></TABLE>
neither have i but i knew that statement couldnt be true...
Old Jun 11, 2007 | 10:12 AM
Sean Juan's Avatar
Default Re: (wifesaynogo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wifesaynogo &raquo;</TD></TR><TR><TD CLASS="quote">whoever said you will be cruising in vtec doesnt know wtf there talking about...even at 75-80 in an ap1 you will be below 6000rpms...practicality is relative...it will be easier for the engine to push/pull the car when accelerating therefore increasing mpg theoretically...mpg is not dependent solely on rpm but also throttle position...thus if u need less throttle to sustain a given speed less fuel consumption...geez</TD></TR></TABLE>
RPM speed is a much bigger factor. Most of the time, higher rpm speed usually means the throttle body will be open more as well in order to sustain that faster speed (and higher rpm). We're not dumb here. You are right about not cruising in vtec though. Take it on mythbusters or something and test your theory though.
Old Jun 11, 2007 | 10:14 AM
S2KILLA's Avatar
Default Re: (Sean Juan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sean Juan &raquo;</TD></TR><TR><TD CLASS="quote">
RPM speed is a much bigger factor. Most of the time, higher rpm speed usually means the throttle body will be open more as well in order to sustain that faster speed (and higher rpm). We're not dumb here. You are right about not cruising in vtec though. Take it on mythbusters or something and test your theory though. </TD></TR></TABLE>
haha ohhh and another thing i forgot, with the 4.56 gears, if you decide to go FI, you will be a lot happier with that gear setup than 4.77's
Old Jun 11, 2007 | 11:57 AM
Lsos's Avatar
Quite the opposite. The best efficiency of an engine is when you give full throttle, because there's less pumping losses. Therefore, the key is to gear it as long as possible, because if rpm are low enough you can cruise with an almost fully open throttle....plus less frictional losses when there's less rpms. This is why Corvettes get good highway mileage. I also remember the CRX HF was geared so high that it could probably go 500mpg given enough power.
Old Jun 11, 2007 | 12:00 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: (Lsos)
Non-sense. I had a CRX HF. Boosted Y6 swap. Gas mileage was decent.
Old Jun 11, 2007 | 01:00 PM
Lsos's Avatar
Default Re: (Mr. Projekt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt &raquo;</TD></TR><TR><TD CLASS="quote">Non-sense. I had a CRX HF. Boosted Y6 swap. Gas mileage was decent.</TD></TR></TABLE>
50 miles a gallon?
Old Jun 11, 2007 | 01:01 PM
* B A N N E D *
Default Re: (Lsos)
More like 30.
Old Jun 11, 2007 | 01:02 PM
Moemers's Avatar
Default Re: (Lsos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lsos &raquo;</TD></TR><TR><TD CLASS="quote">
50 miles a gallon?</TD></TR></TABLE>
Boosted Y6?
46 mpg.
lol.
I'd like to get gears but i'm a scaredy cat.
Old Jun 11, 2007 | 01:03 PM
* B A N N E D *
Default Re: (Moemers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moemers &raquo;</TD></TR><TR><TD CLASS="quote">
I'd like to get gears but i'm a scaredy cat.</TD></TR></TABLE>
Do it.
Old Jun 11, 2007 | 01:28 PM
theres alot more to it than throttle and rpm's...i did not go into deep detail as i thought it was unnecessary...also i could have sworn that all the gas efficient crx's and civics all came with different engines than the top tier models greatly contributing to there fuel efficiency not necessarily just the factor of gearing... it can be complicated to get into but there are numerous geared s2000 owners that have documented no to even an improvement in mpg...being that we neither have hard numbers i will not say you are wrong or that i am right...this is just my opinion
Old Jun 11, 2007 | 01:31 PM
Sean Juan's Avatar
Everyone thinks they're a teacher.
Old Jun 11, 2007 | 01:42 PM
coulda sworn that i said i was neither right nor wrong as we do not have all the facts and still u complain...if i was a teacher i would bust out a book and say page xyz...i clearly said its my opinion...i conceded the discussion...u are entitled to your belief and i respected that
Old Jun 11, 2007 | 02:02 PM
Sean Juan's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wifesaynogo &raquo;</TD></TR><TR><TD CLASS="quote">coulda sworn that i said i was neither right nor wrong as we do not have all the facts and still u complain...if i was a teacher i would bust out a book and say page xyz...i clearly said its my opinion...i conceded the discussion...u are entitled to your belief and i respected that</TD></TR></TABLE>
Who said I was talking to you? lol Btw, there's a difference between stating opinions and false information.
Old Jun 11, 2007 | 02:15 PM
* B A N N E D *
Quit your bickering. There are a few real "teachers" here, and neither of you qualify.
Old Jun 11, 2007 | 02:16 PM
* B A N N E D *
Default Re: FINAL GEAR ????? (ITRbroham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITRbroham &raquo;</TD></TR><TR><TD CLASS="quote">AP1/2 OEM FD is 4.1.
4.7 FD isn't bad for the motor but it will affect top speed while improving acceleration. It will not improve the engine's power number-wise.</TD></TR></TABLE>
Hey LLoyd, how about that Lewis Hamilton huh? He makes me smile.
I'm hoping Sato will do better as the races progress. I don't have high hopes for him at Indy though...
Old Jun 11, 2007 | 08:55 PM
ITRbroham's Avatar
shit post warrior
Default Re: FINAL GEAR ????? (Mr. Projekt)
Hey LLoyd, how about that Lewis Hamilton huh? He makes me smile.</TD></TR></TABLE>
Sup Dang, Lewis is the man! He drove an awesome race this past Sunday.
I'm hoping Sato will do better as the races progress. I don't have high hopes for him at Indy though... </TD></TR></TABLE>
Sato and the Super Aguri really did well at an eventful Canadian GP. I'll be there to see him in person as I will be leaving for Indianapolis on Sat. night.
Old Jun 11, 2007 | 10:48 PM
Techno Tonis's Avatar
Default Re: (ley)
common knowledge was just thrown out the window
