aem cam gear
Old Jun 10, 2007 | 08:10 PM
streetracerjoey210's Avatar
Default aem cam gear
what does it really do.
sohc d16y8 with a aem cam gear....
Old Jun 10, 2007 | 08:12 PM
92ehatch's Avatar
Default Re: aem cam gear (streetracerjoey210)
if its adjustable then you can adjust cam timing with it.
if its not adjustable then its just a bling thang
Old Jun 10, 2007 | 08:13 PM
94c1v1cex's Avatar
ya... the non adjustable ones are pointless unless you just want a blue/red/silver cam gear that you can't even see cause of the timing belt cover... so it's just piece of mind that you have color behind that cover lol
Old Jun 10, 2007 | 08:15 PM
ilovemycoupe's Avatar
I'm a Jackass
allows a tuner to tune the car properly
gives engine unique cool look
replaces old rusty cam gear
does not give any real power gains unless they are used to tune, then you might squeeze a few unseen hp's but when its all said and done unless you are putting down high hp numberws it not needed....
at the least id only put it on if you had
i/h/e, but if you got aftermarket cam's or a built head i'd then suggest on upgrading
p.s.
if not too much to ask see my sig if u get a chance
Old Jun 10, 2007 | 08:19 PM
tru time red one.
does it add h/p
Old Jun 10, 2007 | 08:21 PM
thanks..........
Old Jun 10, 2007 | 08:22 PM
94c1v1cex's Avatar
Default Re: aem cam gear (ilovemycoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ilovemycoupe &raquo;</TD></TR><TR><TD CLASS="quote">
p.s.
if not too much to ask see my sig if u get a chance[/I]</TD></TR></TABLE>
he'll be in my prayers
94c1v1cex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by streetracerjoey210 &raquo;</TD></TR><TR><TD CLASS="quote">tru time red one.
does it add h/p</TD></TR></TABLE>
only if it's used in the tuning process
Old Jun 11, 2007 | 12:59 AM
hidiouskinky's Avatar
Default Re: aem cam gear (94c1v1cex)
when properly tuned....yes they make suffecient gains in HP but if ur gonna get AEM cam gears, get the tru time cam gears with 5 bolts ive seen the ones with 3 bolts strip too many times
Old Jun 11, 2007 | 04:54 AM
EM-One's Avatar
If you have a stock motor, then it is pretty pointless b/c you should change your factory timing.
If you have a built motor, then you or your tuner can adjust the timing when tuning to squeeze a few extra horsepower with the setup. For the full effect, you should also be running the AEM underpully's as well. They add approx. 6-9hp to your set up when tuned in perfect.
wako182774
Honda Civic (2001 - 2005)
Jun 16, 2007 05:29 AM
sk8shorty012
Mar 13, 2006 11:26 AM
jdm4drSi
May 12, 2005 02:28 PM
casmello
Jan 6, 2005 04:41 AM
BoostinEJ1
Jan 29, 2004 11:49 AM
