quik Injector Q
Hey im about to install a turbo on my civic but i was wondering if im suppose to buy a resistor box for my DSM or anything else thanx for any input!!! They are going in a 93 honda civic
Anybody else that can clarify some more!! Someone before told me i didnt need any resistor box or anything true or not!!! Sorry im just trying to get much info so i dont buy the wrong ****
THANX TO ANYONE WHO HELPS
Dsm injectors are peak and hold. which are low impedence. Regular injectors for hondas and acuras are saturated, or high impedence. You need a resistor box to change over from what came stock in your car, the saturated injectors to the dsm peak and hold injectors. I believe preludes may have peak and hold, but I'm pretty sure that other hondas do not. 5G civics for sure use saturated.
you do have the 450cc dsm injectors, correct?
Here is a link that may help you out...
They list an alternative way of how to wire it up, without having to purchase a resistor box.
http://www.homemadeturbo.com/t....html
Hope this helps.
Hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by numbnuts22715 »</TD></TR><TR><TD CLASS="quote">what do you mean ease it up? Either way works fine, the wawy in the link is the cheapest, and probably fastest so you dont have to wait on any part.</TD></TR></TABLE>Well im ordering it all together if it is needed to get the resistor!! do you know if the plugs are ok or should i buy the injector plugs resistor box combo from the store im going to order from? THANX FOR ALL YOUR HELP SO FAR
I think you need obd1 injector clips. Im pretty sure you can find out for sure through searching. I havent ever used dsm injectors, but I know when I used my rc injectors, I needed obd1 injector clips.
the gsm injectors are obd1, so youll need obd1 clips as well.
