igintion coil
car is 1994 accord lx, my question is i had to remove my t-stat housing i had to remove my ignition coil box. my issue is i forgot how the ignition box goes back on cause it looks like the one bolt that holds the t-stat housing also holds on to the bracket that holds the ignition box. i hope this makes sense to someone who has done work in that part of their car if u have a pic please post it so i can see what i did wrong.
thanks for replying,
i don't mean the two 10 mm bolts where the lower RAD hose is connected, i meant on the housing itself where the bleed bolt is there are two 12 mm bolts, do they hold onto the ignition coil bracket or do they just hold the housing. cause it don't make make sense to hold a ignition coil and the housing together. if it's not much to ask can someone take a look, being you have the smae year and model. I'm almost with doing what i need to do but i'm stumped as to how all this goes back on, don't wanna say "o that's how it goes" and end up with a leak. anway lemme stop rumbling
again thank for replying honda dude
loki2323
Sep 3, 2005 10:38 AM
