cooalnt foam
Old Jun 10, 2007 | 05:30 PM
djsire's Avatar
Default cooalnt foam
just had to change my lower radiator hose.
when i filled up the radiator it started faoming like the head of a beer. for about 10 minutes. then it stopped?
do i have a headgasket problem?
Old Jun 11, 2007 | 06:14 AM
ek4_b16a's Avatar
Default Re: cooalnt foam (djsire)
bump i would like to know also
Old Jun 11, 2007 | 08:06 AM
djsire's Avatar
Default Re: cooalnt foam (ek4_b16a)
any one?
Old Jun 13, 2007 | 04:25 AM
djsire's Avatar
hello!!
Old Jun 13, 2007 | 04:32 AM
g23_ej1's Avatar
i doubt it.. after you drain your coolant, you have to bleed your system like you would your brakes.. air builds up into your cooling system, it'll cause it to possibly blow your water pump, overheat etc.. the foam you were seeing is a good thing.. air was just getting out of the system..
did you bleed your cooling system at all?
Old Jun 13, 2007 | 06:52 AM
djsire's Avatar
Default Re: cooalnt foam (g23_ej1)
left the car running with cap off for 10 minutes.
the car had one front wheel on the side walk(elevated)
drove for two days no more overheating
Old Jun 13, 2007 | 07:02 AM
g23_ej1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">left the car running with cap off for 10 minutes.
drove for two days no more overheating</TD></TR></TABLE>
there you go, so you should've known that the foam was air in your system...
Old Jun 13, 2007 | 02:46 PM
djsire's Avatar
ive never seen it foam like that before.
i know about bubles but it literally looked like i was poauring beer in there
Old Jun 13, 2007 | 03:27 PM
g23_ej1's Avatar
yea, it does look like that.. ive had that and just basic bubbles.. you probaly got alot of foam since it was the lower hose
Doh!
32
May 16, 2007 08:22 PM
MONTELIOUS
Aug 23, 2006 12:41 PM
blackpearlv6
Jun 8, 2006 11:04 AM
gsrcxhatch
May 11, 2006 07:37 PM
