accord dsm turbo 4th gen
Old Jun 10, 2007 | 05:22 PM
zigg_1311's Avatar
Default accord dsm turbo 4th gen
i was wanting to know if i did a h23a head swap and intake manifold, if my dsm turbo was still going to bolt up to my f22a, dont think it will, but should i just swap the head and intake and get a new turbo manifold, or should i just leave the sohc head, swap the intake mani. and keep the same turbo manifold?
Old Jun 10, 2007 | 05:56 PM
jabontke's Avatar
Default Re: accord dsm turbo 4th gen (zigg_1311)
Are you planning to use a turbo manifold from a Mitsubishi? If so then no, it will not work. You would need a turbo manifold that fits a honda cylinder head. What do you want an H23a head? If you are going to do a turbo setup, it is not going to get you any more power.
A DOHC head will help more air enter a naturally aspirated engine, but if you are forcing the air in by means of a turbo, SOHC will be fine. I would get the correct exhaust manifold that fits the honda and GSM turbo, add the intake and exhaust piping and call it done.
Old Jul 23, 2007 | 11:20 AM
Andryzzle's Avatar
Default Re: accord dsm turbo 4th gen (jabontke)
the f22a exhaust ports are the same as the h23 non-vtec ports so unless there is a clearance issue somewhere i dont see why the dsm manifold that fits the f22a will not fit the h23...
Lazysk8r2
Sep 16, 2014 06:53 PM
JKov240
Apr 10, 2009 09:40 AM
mkw1
Welding / Fabrication
34
Aug 11, 2008 04:43 PM
spcrxracer
Oct 2, 2004 11:03 PM
Brandon
Jan 20, 2003 11:53 PM
