OBDII to obdI
Old Jun 4, 2002 | 04:46 PM
Stewie's Avatar
Default OBDII to obdI
What would it take to swap my OBDII LS for a OBDI LS ECU. Can I use my wiring harness or will I have to rewire everything.
thanks
ps I did a serch and couldn't find anything.
Old Jun 4, 2002 | 05:17 PM
Jackson's Avatar
Default Re: OBDII to obdI (Mac8008)
You will need one of these and an obd 1 ls ecu.
Old Jun 4, 2002 | 08:21 PM
Stewie's Avatar
Default Re: OBDII to obdI (Jedi Master)
Can you please give me more info like were I can find one of those? Does it just all hook up?
thanks
Old Jun 4, 2002 | 09:02 PM
Jackson's Avatar
Most shops carry them. Its an ecu jumper harness. It runs about $250 or so. I got the pic from http://www.inlinefour.com
Old Jun 4, 2002 | 11:02 PM
Jaker's Avatar
We produce some of these and have them available through a few shops in the US. http://www.C-SpeedRacing.Com, and http://www.JDMHondaparts.Com.
Old Jun 5, 2002 | 03:24 AM
kenji's Avatar
Default Re: OBDII to obdI (Jaker)
I can make the harness you need. Email me for more info.
-kenji
Old Jun 5, 2002 | 07:11 PM
EGHatchy's Avatar
Default Re: OBDII to obdI (kenji)
when going from OBD-II to OBD-I or OBD-I to pre-OBD, and getting those ECU adapters, is there any other modifications needed to any other wiring?
Old Jun 6, 2002 | 06:16 AM
kenji's Avatar
Default Re: OBDII to obdI (EGHatchy)
When going from OBD2 (verson 1 and 2) to OBD1 there are no modifications necessary. Unless you have a GS-R and intend on keeping the dual plane intake manifold with the IAB.
When going from OBD1 to 'Pre OBD' there are wiring modifications necessary (e.g. injector resistor box, distributor, injectors, etc.).
-kenji
ek9ina
Mar 13, 2014 09:30 PM
legend99
11
Apr 3, 2012 04:47 AM
sik96teg
16
May 26, 2006 11:23 AM
ransack
Nov 26, 2002 09:03 PM
DevinW
Aug 18, 2002 06:50 AM
