JVC 12CD Changer CH-X1500RF wiring
Old Jun 10, 2007 | 05:06 PM
Tano's Avatar
Default JVC 12CD Changer CH-X1500RF wiring
I have a problem with install this CD changer. It comes with 1 CD changer <--> FM modulator. FM modulator comes out with 3 wires: black (ground), red (power)(with 3A fuse on-wire), and yellow (memory backup power)(with 3A fuse on-wire). I tried to connect to wiring harness first (already have black,red, yelllow). No power comes up from main unit. Then I tried to connect the red to left side fuse panel using a add-to-circuit fuse (with a red wire come out), and black to chassis, yellow (just leave there, don't know where it should go???). No power comes up either. I believe this refurbished unit is defective. Any idea to test if this unit works or not and how to wire correctly?
Thank you so much!!!
Old Jun 10, 2007 | 05:41 PM
B18C_EJ8's Avatar
The red, yellow & black wires in the harness going to your radio (providing it's an aftermarket unit and not stock) should be adequate to power the changer...
If you connected those wires and you got no power, I would first check the fuse(s) on the power wires for the changer. (And by check, I mean verify for continuity with a meter, not just looking at them.) If the fuses test OK, then there may be a problem with the changer.
Year/Make/Model of vehicle please?
Old Jun 10, 2007 | 07:43 PM
Tano's Avatar
Default Re: JVC 12CD Changer CH-X1500RF wiring (Tano)
I did all that you have said, except for the fuse ( I just look at them) hehe...Does that make any difference??? So how do I test the fuse? It's a long,glass oneMine is a Honda Accord 99 LX. Thanks for replying.
Old Jun 11, 2007 | 04:37 AM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tano &raquo;</TD></TR><TR><TD CLASS="quote">Does that make any difference??? So how do I test the fuse? It's a long,glass one</TD></TR></TABLE>
If it didn't matter, would I have wasted my time typing it??
Test it with a meter....
Old Jun 14, 2007 | 07:41 AM
Tano's Avatar
I did try to take the fuse out and connect the wire directly, still there is no power? Does the yellow also need connected??? On the fuse panel? which one is for the right one and which fuse for the red one??? (Supposedly, interior fuse panel, driver side- Accord 99 LX)
hondaboyqj
Feb 5, 2019 06:28 PM
Tano
Jun 10, 2007 01:41 PM
SupaFly_Honda
Audio / Security / Video
Dec 18, 2006 10:15 AM
importracegirl
Nov 21, 2006 12:47 AM
