Clutch Spec
Old Jun 10, 2007 | 04:05 PM
cmasonrun's Avatar
Default Clutch Spec
What is the ft. lbs torque spec. for B16
Old Jun 10, 2007 | 04:09 PM
EG2Driver's Avatar
Default Re: Clutch Spec (cmasonrun)
you don't bolt the clutch on. Do you want the flywheel to crank or Pressure Plate to flywheel?
Flywheel to crank = 87 ft/lbs
Pressure Plate to flywheel = 19 ft/lbs
Both use a 12 point socket, and must be tightened in a criss-cross pattern.
Old Jun 10, 2007 | 04:16 PM
cmasonrun's Avatar
Default Re: Clutch Spec (EG2Driver)
Pressure Plate??
Old Jun 10, 2007 | 04:44 PM
EG2Driver's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmasonrun &raquo;</TD></TR><TR><TD CLASS="quote">Pressure Plate??</TD></TR></TABLE>
Yes
t0p_sh0tta
Jun 9, 2014 10:35 AM
95_red_dc
Transmission & Drivetrain
Sep 5, 2008 02:38 AM
95_red_dc
Sep 2, 2008 06:19 PM
turkeyslow
Feb 13, 2008 10:18 AM
jdmCivic925
Jul 28, 2004 10:11 PM
