Cam holders interchangeable between engines on D16Z6?
Old Jun 10, 2007 | 03:47 PM
on2wheels's Avatar
Default Cam holders interchangeable between engines on D16Z6?
The part of the cam holder that the valve cover bolt screws into busted off on a D16Z6 I have.
My question is, can I replace the cam holder with one from any D16Z6? The cam holders don't have to match the block like the rocker shaft collars do, or anything funny like that, do they?
Thanks.
Old Jun 11, 2007 | 07:34 AM
mahatma's Avatar
Default Re: Cam holders interchangeable between engines on D16Z6? (on2wheels)
cam holder, as in the cam caps (little U shaped parts that hold your cam in place)??
if so, then those are not interchangable. people throw heads away if they don't have the matching cam caps.
it COULD work, but you run the risk of the journals being out of round, unless you have them align-bored.
Old Jun 13, 2007 | 09:01 PM
on2wheels's Avatar
Default Re: Cam holders interchangeable between engines on D16Z6? (mahatma)
Thanks.
Found lots of info. searching for cam caps instead of cam holder.
drlagares
Apr 15, 2018 11:39 AM
50-50
Oct 23, 2009 01:40 PM
aemfreak
Oct 28, 2006 09:15 AM
d357r0y
May 6, 2002 07:04 AM
