si engine harness/ecu harness
I got a 96cx hatch and i put a swap in it and i changed the engine harness to si and i got the boomslang obd2b to obd1 jumperharness and it plugs in but there seems to be that the engine harness is missing a plug and im not sure so i figured i would post on here and see.
well today im going to use my friends si ecu to see if it starts but i need another jumper harness for si harness. i got a obd2b jumper harness already but it seems like its missing a clip that plugs into the jumper. the computer im trying to run is a chipped p28
It looks like you have the B and C connector for the ECU. Where the hell is the A connector. It's another gray one that plugs into your conversion harness. Leave the green male pluged to the green female.
Did you drop in a B16? You do have a OBD2b -> OBD1 coversion harness right?
si have a two part harness the other plugs on the interior wiring harness even if u have a ob2b to obd1 u still need the other plug so unless u plan on swaping the whole interior harness u need 2 run a 96-98 ex wiring harness with a obd2a to obd 1 conversion
thekid2390
Jun 18, 2013 11:36 AM
clark81
Sep 5, 2010 11:52 AM
