what are the lightest and heaviest stock 4th gen rims?
A wile back i ran over a pretty big drill bit in the road and instead of just poping my tire like a normal metal thing, it had to put a hole in my rim to. im a little poor right now so it will be a wile befor i can get some aftermarket rims. im thinking about going to the junk yard but i dont think il be able find my same rims since i have a 94 vtec and its not common at all over were i live so i was thinking about getting a set of the other stock prelude rims (if they will have that either). but if the wieght on the others are more il probably just not worry about it right now. so i was just wondering if anyone out their knew what are the lightest and heaviest stock 4th gen rims?
w/o doing a search I can tell you the sawblades or the SE rims are the lightest around 17lb each and the SI 7 spoke(?) were around 22lb.
I think the lightest OEM wheels that will fit are the ITR's but I'm not sure the cost or weight. If you want more info or a more "Set in Stone" answer look for the red <U>Search</U> link at the top right corner of every page.
If you like these, and are willing to make the drive up to Knoxville, I'm selling them for $350 wheels and tires. Each rim is 16.5lbs
http://memimage.cardomain.net/...l.jpg
i might just have to do that. how long would you hold on to them because i just cracked my radiator today so im going to have to replace it first befor i drive anywere. would you take 300 since that is a long drive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by M@ »</TD></TR><TR><TD CLASS="quote">w/o doing a search I can tell you the sawblades or the SE rims are the lightest around 17lb each and the SI 7 spoke(?) were around 22lb.
.</TD></TR></TABLE>
93 VTECs came with the 7 spoke as well....
.</TD></TR></TABLE>
