brakes rubbing rotors
Old Jun 10, 2007 | 12:16 PM
the.hamburglar's Avatar
Default brakes rubbing rotors
are there any ways or tips to bleed my braking system so that none of the pads on my 4 wheel disc brakes actually touch to rotor? when my car is jacked up the wheels are kind of hard to turn.
Old Jun 10, 2007 | 12:19 PM
bmoua's Avatar
Default Re: brakes rubbing rotors (the.hamburglar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the.hamburglar &raquo;</TD></TR><TR><TD CLASS="quote">are there any ways or tips to bleed my braking system so that none of the pads on my 4 wheel disc brakes actually touch to rotor? when my car is jacked up the wheels are kind of hard to turn.</TD></TR></TABLE>
bleading the rotors is just unscrewing the 10mm bolt on the caliper. Your rotor/brake question has nothing to do with bleeding the brake system. Make sure you use dot 3 brake fluid and bleed from rear driver, rear passenger, front passenger, ending at front driver.
Old Jun 10, 2007 | 03:42 PM
Default Re: brakes rubbing rotors (bmoua)
of course it does... my pads are touching the rotor and i cant think of any other way to release the pad but to remove some brake fluid. what else can i do so that my pads dont rub on the rotors (when my my foot is not applied to the brakes).
Old Jun 10, 2007 | 05:38 PM
RedEj8's Avatar
Your pads should be touching the rotors at all times..Theres really no way that they wouldnt be touching it. You wheel should not be super hard to turn tho...IF your trying to turn your front wheels while in the air are you sure your car is not in gear? If your turning the back wheels are you sure your ebrake is not engaged?
Old Jun 11, 2007 | 10:31 PM
civiclx93's Avatar
any progress my pads are doing the same thing could it be the caliper is not set right?
Old Jun 12, 2007 | 05:07 PM
Default Re: (civiclx93)
nope, there should be minimal drag on the rotor but it seems like nobody knows what i mean and are just worried about getting their body kit fit right
Old Jun 12, 2007 | 05:10 PM
SoullessJapaneseMachine's Avatar
Default Re: brakes rubbing rotors (RedEj8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedEj8 &raquo;</TD></TR><TR><TD CLASS="quote">Your pads should be touching the rotors at all times..Theres really no way that they wouldnt be touching it. You wheel should not be super hard to turn tho...IF your trying to turn your front wheels while in the air are you sure your car is not in gear? If your turning the back wheels are you sure your ebrake is not engaged?</TD></TR></TABLE>
Old Jun 12, 2007 | 05:13 PM
95DxSi-R2
Guest
Posts: n/a
maybe your caliper is sticking? and u don't want to remove brake fluid from your <U>braking system</U> lol
is your rotor out of round, can u spin the tire/wheel freely when off the ground?
and what do u mean by jacked up?
wxy117
Apr 25, 2008 06:22 PM
realis9
Feb 16, 2006 05:41 PM
ebonyrolla7
Nov 22, 2005 07:06 PM
ninor
Acura TSX
12
Jan 17, 2005 08:24 AM
wizzards581
16
Sep 17, 2003 06:16 PM
