1gen Header QUESTION
Old Jun 4, 2002 | 03:44 PM
JStone2775's Avatar
Default 1gen Header QUESTION
WILL Si headers fit my DX motor
87 CRX DX
Old Jun 4, 2002 | 03:47 PM
-TJ's Avatar
-TJ
Default Re: 1gen Header QUESTION (JStone2775)
any 84-87 header will fit your motor, regardless of trim level. For any performance parts, about the only place that still sells 84-87 Civic/CRX stuff is OPM motorsports - http://www.opmmotorsports.com/
Old Jun 4, 2002 | 05:15 PM
rpr's Avatar
rpr
Default Re: 1gen Header QUESTION (-TJ)
Wrong. The oilpan on the DX is shaped differently, so an SI header will NOT fit unless you change the oil pan. Chikara (Hedman) has a header for the DX. And OPM is not the only place that sells performance parts for the 1G.
[Modified by rpr, 9:16 PM 6/4/2002]
Old Jun 5, 2002 | 09:54 AM
crxfanatic's Avatar
New User
Default Re: 1gen Header QUESTION (rpr)
DC Sports is also making stuff for 1st gen, headers, strut bars, short shifters...
Chikara/Hedman has decent cheap headers. Ground COntrol has all the suspension stuff you'll need.
OPM is great, but a bit pricey on some stuff you can find elsewhere, like headers and sway bars.
Similar to what RPR said, the Si pan is needed if you want to use an Si header on the DX. Also if you have emissions tests, be warned that the cat is bypassed in the swap, as the DX cat is stuck right on a shorty exhaust manifold in front of the motor, not below after a downpipe. The Si stuff bolts right to the DX b-pipe, which is cool, but you'd prolly want a better 2 inch system after the header.
[Modified by crxfanatic, 7:00 PM 6/5/2002]
austinwb
Honda Civic (2001 - 2005)
Feb 27, 2008 08:57 PM
Todd00
Sep 26, 2003 02:04 PM
JStone2775
Jul 9, 2002 06:27 AM
vtec-outlaw
Jun 26, 2002 02:16 AM
The_Robster
Jun 5, 2002 05:40 PM
